I keep my f250 clean,not a work truck,daily driver,99% pavement driven,and I have had an issue that is being resolved BOTH driver side and passenger side windows(front) I have a crew cab, I assume the seals have failed,the glass 3/4 of the way up have developed scratches deep enough to feel with your fingers and fingernails,i rarely roll down my windows....wow it makes a horrible noise goimg up and down,the rear windows good to go.....anyone else hear of this or had this happen to them,only 24k on the odometer and I bought it brand new.
there is a TSB for this issue. My truck has them as well.
Mine too-looks even worse on tinted trucks.
I am starting to develope these stractches on my drivers side window. I am about to order another outer seal from tasca and see if it stops getting worse.
What other TSB's should I be aware of?
my 05 started getting scratches and had to replace the weather stripping at bottom of window, the fur or soft part wore off and anything that got in the seal would grind going up and down. so far our 2010 isnt doing it yet
mine has scratches on my drivers side window front... just in the corner nearest the rear.
that's a recall i believe, so its a fix, no warranty needed.....its a ford thing. i always run my fingers between the outer wiper and the window to make sure nothing is in there....
Mine is currently doing it.
Mine looks like I've rubbed sandpaper on my window in the sunlight.
