Recent 08 F350 Purchase... need help getting rid of emmissions BS!
I recently purchased a 2008 F350 King Ranch and it is awesome! It has 40K miles on it and I purchased the extra warranty up to 100K. I want to get rid of all the BS on the exhaust, DPF delete, etc and buy a programmer to make it run better but it will void the warranty from what i've heard....
Any Ideas??? I've thrown around the idea of buying a whole new turbo back exhaust and keeping the stock one and if I had problems delete the program and put it back to stock as well as put the stock exhaust back on. Input?? Thanks everyone for your help! |
Why did you purchase the extended warranty if you plan on deleting the truck? The deletes will void your warranty. As far as returning the vehicle to stock goes, tuners can be traced if the tech knows what they're doing and if there is a major issue with the truck, Ford will dive deep into the truck to ensure that it is a "true" warranty claim. Also, the most worthwhile mod for reliability is doing the EGR delete and that is a rather lengthy process to get rid of to begin with. I was quoted 9 hours labor (this is what the shop averages) for total removal of both EGR coolers and this was with the cab lifted.
I guess I wasn't thinking to put it simply. I have friends who also have the same year of pickup and they talked about how they were doing this, later to find out they had well over 60K miles on theirs and it didn't matter to them because they were already past warranty anyways. I just assumed that it was fine to do it not knowing that it voided the warranty. I found out too late basically. Allegedly I've heard the dealers can't do anything as long as you take it back stock. (I could be misled on this as well) When you delete the program it just shows that your battery has been recently disconnected and says nothing more, again not sure if this is true. It's hard to get correct information these days. Thanks for your time.
If you paid for the extended warranty, you might as well keep the truck stock. If you can cancel/opt out of the extended warranty, I'd go and get the truck tuned. Why take the risk at your warranty being voided after shelling out all that money on an extended warranty that yo may not be able to use? |
A simple tuner (H&S), dpf delete and exhaust will work great. A simple dpf back exhaust will not do much good. You might have warranty issues unless you put the truck back to stock before any work is done.
As for the EGR delete, many have reported doing this in the driveway in WELL under 9 hrs. LOL The EGR delete kit is worth the money and the install is pretty straight forward. |
I thought that the tuners leave a combustion pattern (star) on the pistons due to the improved tuning?
If so, there is no way to return that back to stock. You would have to have major problem to have them pull a head in diagnosis and discover that, but then again a major fubar is where you want the warranty coverage the most. Personally, I don't like extended warranties. They sell them for a reason. Ask an actuary why. Of course, YMMV ! Shawn |
I also think my age plays a major factor in the service I receive. Being young and owning an expensive truck doesn't get you treated very well, when you're dealing with older service writers that think you're a silver spoon. |
I'm a technician for a ford dealership. Why would we say no to warranty work? It's money in our pocket. Sure we like to do retail jobs better than warranty, but if you are good at what you do you should have no problem doing the jobs in the time warranty allows. It pretty much all comes down to the story you write for the repair you made, good story = get paid in full for all work done. We could care less if your truck comes in the shop modified, we'll fix it. Only time issues ever really come up is when prior approval wants detailed pictures of various areas of the truck. Even then, they have approved many jobs on modified trucks.
