Questions about EGR block off plate - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-29-2011, 11:25 AM Thread Starter
if I do the egr block off plates do i need to tune or anything?? Also with the block off plates can the valve still fail and cause problems?? the only reason i want to do the block off is to prevent the valve from ever failing so if it can still fail theres no real point to it. Thanks.
2008 f350 srw
Ericr712 is offline
post #2 of 4 Old 11-29-2011, 12:08 PM
amb82's Avatar
Feedback Score: 3 reviews
Yes you would need a tuner that will completely turn off the egr function. You can't delete any of the emissions stuff on these trucks with out a tuner that allows you to do so. I would think that it would throw codes and possible go into limp mode
2010 F-250 Cabelas Edition
Sct with Gearhead tunes, 4" afe dpf delete exhaust, leveled on 22's
amb82 is offline
post #3 of 4 Old 11-29-2011, 12:23 PM
i'm thinking about block off plates as well. I'll keep an eye on this.
'08 F-250 King Ranch SB CC
Sct Livewire Extreme
KEM 250 Tuned
AFE Stage II CAI
DPF/DOC Delete
Boy this sure does get out of hand quickly!!!
Other Toy:
1956 Ford Thunderbird 312cid V8 Ford-omatic trans
Complete body off restore in 2002
Peakc0ck Blue with White tops and power seats
usudno is offline
post #4 of 4 Old 11-30-2011, 12:56 AM
hyrczyk's Avatar
I'm also looking at doing this to my 08 f250 but then saw that the H&S can just turn off the egr. Would there be a need to do a block off plate if it is turned off?
hyrczyk is offline
