need some 6.4 info - Ford Powerstroke Diesel Forum
Old 11-18-2011, 07:50 AM
need some 6.4 info
ok well im new to powerstrokes kinda and im looking to get one. i like the 6.4 cause my ol man has one but he has had some egr problems. what with everyone saying job 1 and 2 and so on? whats the difference between them and which ones are better? i was thinking about getting an 09 or 10 just to not have to worry about all the bugs from the 08's. any opinions? and what do yall prefer h&s or spartan? and what would you do to a 6.4 to make it reasonably reliable and powerful?
thanks,
brad
Old 11-18-2011, 10:46 AM
thanks,
brad
well if you can do an 09 or 10 i would if the deal is right, i would not however worry about an 08,,its very solid with limited issues do to new model . Hand S all the way on tuning..H&S will make it more powerful then you will believe, dpf delete , ccv mod, and at some point a EGR delete and you are good to go, in my opinion....good luck
Old 11-18-2011, 11:34 AM
Thanks man. But should I stay away from the job 1? And what would classify it as a job one?
Old 11-18-2011, 04:11 PM
i have a job 1 140,000km and no issues at all its actually the best truck i have ever owned
Old 11-18-2011, 07:48 PM
That's good to hear. I guess it's different for every truck. We have 18k miles on our 08 DRW and the egr went out last month when I was driving it. Oh well. Thanks for the help guys
Old 11-18-2011, 07:53 PM
Job 1's arent bad. Most of the bugs were fixed or covered by warranty. Only real thing for concern is the tcm if you arw going to go high power spartan tunes. Other than that there were some radiator problems fixed by recall, programming, fixed by recall, and i think thats it. Only issues i've had are two leaking radiator hoses and a stuck egr valve (which ford has since upgraded).
Only reason to stay away feoma job 1 is if the things listed above were not fixed under warranty- most important being the venturi tee which addresses the radiator issue as those cost about1k in parts alone. If you can confirm they were fixed and arent planning on runningsuper high hp tunes (tcm runs about 650 bucks) i dont see why you should runaway.
Old 11-18-2011, 08:03 PM
So oasis report is a good idear if it's a job one?
Old 11-18-2011, 08:36 PM
no sticker on pillar when you open drivers door,,, job1 will have 2007 build date....im not sure of all the dates, info is on here though, but if its early o7 definitely a job1
Old 11-18-2011, 09:38 PM
mine is really early 01/07
Old 11-20-2011, 09:39 PM
When buying used pasis is always a good idea! I would never talk you out of that.
