Remote Starter Problem (won't crank)
Hey guys, I have an 08 f350 KR that came with ford's remote starter. It's always worked well then a few days ago I installed an LED lightbar and had to D/C the battery for a few hours. Since the the aux switch wires are in the foot well close to the remote start module I had to cut the zip ties and move it a few inches, feed the wire then zip tied it back up. Ever since then my remote starter hasn't worked. I click the start button, the horn honks, ignition & glow plugs start then after 10 secs when its supposed to start the horn chirps once then nothing. I was gentle when I moved the module, I didn't twist or stress any wires.
Any idea if unplugging the battery for so long may have de-programmed it or something? Help?
i have a ford remote start aswell and i have a reset button on mine its not on the module but its a seperate button beside the obd cord thing i think it was installed after the dealer got it but yours could be different. im sure there is a way to reset it somehow
maybe try with it with the key in the ignition so it for sure has power see if that changes anything
I had this happen to my 09. cycling the keys worked for me. Put first key in and turn key on but dont start the truck. wait 10 seconds. turn off and do the same with your second key. turn on, wait 10 seconds. take out key and try the remote start.
