How many miles are on your rig?
It has around 70000 miles, I just bought it a few weeks ago, and dont remember seeing this, but you know how dealership can be! I also had a dpf delete, a h&s tuner with a egr delete as well?
Thanks. |
Looking at your pictures it is hard to tell where the leak is coming from. Is it the corner of the pan leaking, or is it coming from above and dripping on the pan then down? I would clean the motor the best you can and put some dye in and see if you can track down the origin of the leak.
That is such a coincidence, I spotted the same exact oil leak on my truck yesterday evening and was going to take a picture of it and post it up on here. I'm going to be taking a look at it today and try to figure out where it is coming from.
Well if you figure it out post up on here.
I cleaned off the area somewhat in the picture last night, and drove the truck for about 15 minutes, and there was fresh oil on the silver colored part?? I m just not sure where its coming from. |
Here is my leak, can't tell where its coming from.
hhmmm.....
Front oil seal, had mine replaced at 7,000 miles, a day job at the dealer.
Overfilled oil will cause oil leaks.
