750CCA + 850CCA?? - Ford Powerstroke Diesel Forum
Old 11-10-2011, 08:48 PM
750CCA + 850CCA??
Hey guys, I know this is a dumb question and I hate to ask it but being a grad student strapped on cash I wanted some input. One of my 750CCA batteries that came stock in my '08 6.4L just got a bad cell and needs to be replaced, the other checked out fine. I have one good 850CCA (all Motorcrafts) that I took out of my '04 6.0L when I replaced both of the batteries in that truck last year. Is it a bad idea to use a 850 and 750 CCA battery together in my 6.4L? I feel like if there is an issue it would be the 750 battery possibly getting damaged from too much current but I don't see an issue other than this. I would like to get two 850CCA put in this truck but if I can go without spending the extra money until after the holidays that would be even better. Any ideas??
Old 11-10-2011, 09:11 PM
From what i know it shouldnt be a problem if both batteries are good.
It is bad to leave a bat with a dead cell in the system! The good bat will constantly
try to charge the bat with low voltage and that will ruin the good one.
I ran a 800cca optima and a 850cca napa bat in at the same time. Not for a long time but it was fine.
Old 11-11-2011, 02:16 AM
It will shorten the battery life, but for a short time it will be fine. Defiantly better than having a battery with a shorted cell mixed with a good one.
Old 11-13-2011, 05:28 AM
You'll be fine for a long time. I worked in a junk yard when I was younger and they used whatever they could pull out of the yard for the company trucks. All of them had mismatched batteries, with no issues ever because of it.
Old 11-13-2011, 06:50 AM
Will work fine. When one of those fail and you are forced to buy I would buy two Motorcraft 850s.
