another oil question
how much oil does it take?
ALL powerstrokes hold 15 quarts with filter
thanks
Actually the 6.7 takes 13 quarts with filter.
This is true on 6.7 but to me its not a powerstroke cause its a Ford diesel not navistar
Powerstroke is a Ford trademark.
How sad is it that on a Powerstroke forum the word Powerstroke shows up a miss-spelling. |
Nevertheless, this is the 6.4 forum and the answer is 15 quarts.
I would definitely reccomend only putting in 14 quarts AT FIRST, and THEN start it and let it run a sec.... then shut it off and let settle again before you check it. Its easier to add oil then to remove it if its over full. I did this, and mine was almost to the "MAX" line. I didnt add the last quart. I guess not all the oil gets drained out (even after letting it drain for 15 minutes).
