What is the unofficial checklist of things to do to a high mileage psd? - Ford Powerstroke Diesel Forum
Old 11-07-2011, 03:25 PM
I have been having my truck for a month now and i had ford run an oasis. only thing done was recalls some tsb's and radiator and a stuck egr valve. Mods are in my sig. dpf/doc delete on the way as well as afe stage II should be here tommorow. What should i do before getting to carried away. Filters,coolant,anything else i should check. can i monitor anything important with the livewire? thanks for the help.
Old 11-07-2011, 06:55 PM
BUMP.. i too am interested
Old 11-07-2011, 07:52 PM
ENGINE HOURS!!!!!!!!!!!!!!! idling is horrible for a stock 6.4
Old 11-07-2011, 10:10 PM
With the dpf delete and tuner would idling be as much of a issue? Or would a high idle mod be worth adding to a stock or deleted/tuned truck?
Old 11-07-2011, 10:13 PM
Idling a deleted truck is pretty much a non issue
Old 11-07-2011, 10:34 PM
Thank you for that info.
Old 11-08-2011, 11:26 AM
bump for the rest. Thanks for the info provided.
