Bed cover with power lock... Where to tap into truck harness? - Ford Powerstroke Diesel Forum
Old 11-05-2011, 04:04 PM
Anyone installed one of these? Where did you tap into your truck harness? And where did you find a diagram? the12volt.com is down
Old 11-06-2011, 05:27 PM
If your truck is 08 then blue/light green is lock and yellow/purple is unlock. Drivers kick panel in the huge bundle of wires.
If your truck is 09-10 then they are in the same place except lock is blue/green and unlock is same yellow/purple.
These are both negative triggers though. You will need to wire a relay for each one. Unless your bed cover locks are negative trigger also.
