What mods are necessary to delete dpf? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 10-23-2011, 03:55 PM Thread Starter
I am looking at buying a 2008 f250 but i know the fuel mileage isnt good and was wondering what needs to be done to improve that? I have heard you need to delete the dpf but i dont know if that is just putting on an aftermarket exhaust or do i have to add a tuner? And is there anything i should look for that could be wrong with it? It is a super clean truck and has 131000 miles on it . It was a service rig for a construction company and i am suprised at how clean it is for knowing where it came from. It was bought and servised regularly at the dealer it is at. The steering it tight and the ride is smooth. If any of you veterns have any advise i would appreciate it.
curtis60 is offline
post #2 of 20 Old 10-23-2011, 04:02 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
You'll need a tuner to do the DPF delete. You'll also need either a delete pipe or a full exhaust system. The delete pipe will be the cheaper of the two. I'd also recommend an intake and to prolong longevity and reliability, an EGR delete. If the truck was serviced regularly at the dealer, then all the recalls have been performed on it so there shouldn't be anything to worry about.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 20 Old 10-23-2011, 05:51 PM Thread Starter
Thanks any certain companies better than others when it comes to tuners and exhaust for the 6.4?
curtis60 is offline
post #4 of 20 Old 10-23-2011, 05:52 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 20 Old 10-23-2011, 06:00 PM
2003kingranch's Avatar
H&S, sct or spartan. if you dont want to spend a bunch of money a delete pipe is perfect. as long as your not planning on running 345hp tunes. or racing.
Heres a couple of options--
Ford 6.4L Powerstroke H&S Mini Maxx and DPF Delete Pipe Power Package
Ford F250 F350 Powerstroke Diesel 6.4L DPF/CAT DELETE SCT Live 08-10 | eBay
SPARTAN TUNER PHALANX 08-10 POWERSTROKE 6.4L DPF DELETE on eBay!
my personal preference is h&s. but there is nothing wrong with either 3. mainly depends on how much you want to spend and how much power you want
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #6 of 20 Old 10-23-2011, 09:43 PM Thread Starter
I really just better mpg but I would like to have all the extra power when I want it.
curtis60 is offline
post #7 of 20 Old 10-23-2011, 10:54 PM
Back-To-Doo's Avatar
Oh, once you get the extra power .... you want it ALL the time!
'08 F-450 Lariat 4x4, 8" Sky Jacker 4 link suspension lift, custom studded & grooved 285/70R19.5, H&S Black Maxx Hot Damn tuned DPF/Cat Delete, AFE Stage 2 CAI, 4500K HID Head & fog lights, AVIC Z930BT, upgrade 6x8s, 1250w 10" subs, Truxedo deuce tonneau cover, Reese 25K Elite hitch w/stealth mount. Air lift bags w/wireless, El Diablo Air horns, LED lights
Future mods:
Recon lights, Vision X lights, Cervini Ram Air hood, Transflow tank
Back-To-Doo is offline
post #8 of 20 Old 10-23-2011, 11:03 PM
HaysKSFirefighter's Avatar
I would wait a little bit on the tuner side of it, Matt with Gearhead Performance has been beta testing some new tunes, a while back he was claiming low twenties with a crew cab long bed dually...I would personally run one of his tunes that will get better mileage over a lot of other companies who aren't concerned with mileage. Just fyi.
Tornado Alley PowerStrokers Director
2007 F-350 CCLB XLT FX4 ZF6 08 Mirrors, CTS, Gearhead, BD EGR Delete, Coolant filter, B&W, Custom rear springs, still rockin the stock head bolts and clutch!
HaysKSFirefighter is offline
post #9 of 20 Old 10-24-2011, 06:23 AM
DSTRBD's Avatar
H&S Performance tuners are the best on the market in my opinion. We have ran pretty much everything out there and the H&S Mini Maxx cant be beat. The tuning and features of the unit are excellent and they have the best customer support in the business should you have any issues. Dont waste your time on ebay, give us a holler and we can go over all of the different options available and help you make the best decision for your truck. We also have several different package deals that will save you quite a bit of money.
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
post #10 of 20 Old 10-24-2011, 08:13 AM Thread Starter
As far as the exhaust goes do you want one with the bungs or without and would you have any back pressure problems with a 5" without a muffler. It might seem like I'm new to diesels but this is just my first Ford and my first newer diesel with all the emissions crap on it. And I hate to say it but I've been without a diesel for 3 long years and I'm definitely missing it. My last diesel was a 01 cummins that I traded in for a extended cab gas and at the time it seemed like a good idea but now I ready to get a real truck again so I really appreciate all of your guys help.
curtis60 is offline
