no smoke when exhaust cleaning - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-21-2011, 05:24 PM Thread Starter
dutchie88's Avatar
i have put 5000kms on my truck now and have seen the exhaust cleaning thing go on a bunch of times but i never see any smoke when it does it and it doesnt last long maybe 5 seconds at the most. do you guys get alot or any smoke when its doing the cleaning? dumb question here regen is exhaust cleaning right
08 f250 cclb king ranch
hs mini maxx, snb stage 2 intake, 4 inch dp back exhaust 72 gallon fueltank with toolbox in the back
dutchie88 is offline
post #2 of 7 Old 10-21-2011, 05:38 PM
mikes08powerstroke's Avatar
Little Smoke
I somtimes see a little white smoke during regen, but only if I have the hammer down. My regen does last a lot longer than 5 seconds, usually at least 5 minutes.
mikes08powerstroke is offline
post #3 of 7 Old 10-21-2011, 05:42 PM Thread Starter
dutchie88's Avatar
really 5 minutes? wow i always let my truck warm up in the morning since its getting colder sometimes it smokes then but i thought it only cleaned it when its warm
post #4 of 7 Old 10-21-2011, 07:18 PM
44magnum's Avatar
Quoted: 2 Post(s)
Yes they can on occasion smoke during regen, (other than in regen it shouldn't smoke) What color smoke are you getting? But don't be worried allot of them do it and when it does it may be blueish which is also apparently not unusual. I have had my truck for about 15000miles and I have only seen it smoke 3 times. I haven't seen mine go into regen if its cold, so if its smoking white and the engine is cold and its damp out it may be an intercooler problem, there was a recall or something, hopefully someone with more knowledge will come along. Where are you located? I'm asking because I done see people use Kilometers (as opposed to miles) People might get the wrong idea and think your Canadian or something.......
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #5 of 7 Old 10-21-2011, 07:38 PM Thread Starter
dutchie88's Avatar
yea i live in ontario canada it have only seen it smoke when its cooler out so like 6 degrees it could be just fine but i figure i ask u guys for some info
post #6 of 7 Old 10-21-2011, 07:48 PM
44magnum's Avatar
Quoted: 2 Post(s)
Is that 6 degrees F or C? Just messing with you! What I meant by "cold" was is the engine cold? OR had you been driving for a while and the engine is warmed up to normal operating temp. So if it smokes on "Cold" and damp startup look into the intercooler issue, otherwise its normal. Sorry if I made that confusing. Hope this helps.
44magnum is offline
post #7 of 7 Old 10-21-2011, 07:51 PM Thread Starter
dutchie88's Avatar
yea i just noticed it yesterday morning when i fired it up but there is a good possibility that it could be my intercooler sometimes the turbo doesnt seem like it spools up according to the gage
