Reverse Lamps - Ford Powerstroke Diesel Forum
Old 10-16-2011, 05:20 PM
Dont Mess With Texas!
Reverse Lamps
Can someone pull their taillights a take the reverse lamp out and snap a pic and post it on here? becasue i looked on Retro solutions site and went to the sylvania lamp guide and they both said 3156 and i ordered in a set of 3156 led reverse lamps and they are way way to big, turns out it is a 921 because the ones i ordered for my cargo lights fit perfect in there....
anyways i would like to see a pic of someones becasue everyone and everywhere tells me it should be a 3156 and i find this so wierd
Last edited by ThirdCoastStroker; 10-16-2011 at 06:43 PM. Reason: retro solutions not recon
Old 10-16-2011, 05:27 PM
The reverse light bulbs in mine are the same as the cab light bulbs.
Old 10-16-2011, 05:29 PM
Feedback Score: 5 reviews
I think it's a 922 which I think has the same base as a 194
Old 10-16-2011, 05:34 PM
Sorry to hear about your bad luck with the bulbs but thanks for the heads up. Looking at doing some Recon taillights in the not so distant future and want the LED reverse bulbs too.
Old 10-16-2011, 06:03 PM
Ryan, I don't have cab lights yet
Old 10-16-2011, 06:26 PM
I tried to replace mine with 3156's as well, no luck as well. Ryan what are you using for your cab lights? I'm 99% sure my backup lights are much bigger than my cab lights. Also don't mean to change the subject but my taillights have 3 ports for bulbs but only the top 2 are being used, the bottom one is capped, is this normal? Ill try to get a pic in the next couple days.
Old 10-16-2011, 06:44 PM
Yeah 44 the bottom hole on mine is capped as well
Old 10-17-2011, 10:50 AM
bump anyone got pics of their 08 reverse lamps and housing?
this is odd
Old 10-17-2011, 04:53 PM
Dam you are persistant, haha. Here ya go, didnt see a number on the bulb but it does have the same base at my clearence lights but its bigger, considerably bigger. FYI my thumb is about an inch wide.
Old 10-17-2011, 04:55 PM
Sorry for the huge pics, and while I did pul the bulb out I forgot to get a pic of the bulb by itself, but you can kinda see in the pics that the bulb is necked down to the smaller base.
