coolant flush - Ford Powerstroke Diesel Forum
post #1 of 24 Old 10-12-2011, 02:14 PM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
coolant flush
Well i finally got the coolant. All i need to get is the VC9 and a bunch of distilled water. Hopefully i can get it done this weekend or next. Also i will be changing out the thermostat.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #2 of 24 Old 10-12-2011, 03:58 PM
What's the VC9 for?
tensixniner is offline
post #3 of 24 Old 10-13-2011, 05:06 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
Originally Posted by tensixniner View Post
What's the VC9 for?
It cleans the rust and scale out of the cooling system.
08 F350 cc/sb 4X4
post #4 of 24 Old 10-13-2011, 06:12 AM
muntu's Avatar
something to think about
i checked out doing the job myself......butttt..there was alot of reference about a coolant changing machine that must be used to get all the air out of the system [and air trapped is bad news] so i am just saying be alert....i finally chose for to do it.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #5 of 24 Old 10-13-2011, 06:13 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
I thought about it but after a lot of researching it seemed ford didnt really do a good job. I hope it turns out ok.
08 F350 cc/sb 4X4
post #6 of 24 Old 10-13-2011, 07:28 AM
pyro2nite's Avatar
Please post a follow up after the change. Where you drained the coolant etc. Mine will need it in the near future. Thanks.
2008 FX4 SC SB 6 Speed 3:73LS, Transflow, H&S Mini Maxx, KEM Tunes, S&B Intake
pyro2nite is offline
post #7 of 24 Old 10-13-2011, 07:30 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
Will do! I will try and take some pictures
08 F350 cc/sb 4X4
post #8 of 24 Old 10-13-2011, 09:51 AM
the procedure is unlike anything else I have done on gasser trucks. here are the instructions
you should follow,
http://wpnet.us/flush.pdf
some people have had ford do a flush without following this procedure, you really want to go to a ford dealer that does alot of diesel trucks in order to get the proper flush
2009 f250
H0USE is offline
post #9 of 24 Old 10-13-2011, 10:31 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
Thanks for the info bro. I am thinking i will do the flush and leave the thermostats alone. Everything i have read is that they are a PITA to get in and out.
08 F350 cc/sb 4X4
post #10 of 24 Old 10-17-2011, 06:22 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
ok guys well i finished the change. I flushed the system with VC9. I flushed out a bunch of times until the water came out clean. I didnt take out the passenger side block drain because you cant get to it without removing the starter. I refilled with peak final change and changed the coolant filter. After the first flush a lot of sand came out. Here is a picture of the first flush
08 F350 cc/sb 4X4
