40ft weekend warrior towing - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 22 Old 10-03-2011, 12:16 PM Thread Starter
Originally Posted by smotrs View Post
Here's the specs on the 6.4's
As you can see, the F250 will not support that sized trailer unless it's a 5th wheel. The F350 will be right on the bubble but still unsafe. The only one that can safely pull that load will be the F450.
Mind you, the above numbers are based on a 2008 model, but they didn't change the payloads until 2011's came out and not for the better. You actually lose towing capacity on the 2011's and newer trucks.
Slightly Off Topic: I'd like to see a picture of that thing with your truck in front. That's gotta look crazy.
im confused what are you so mad about alberta according to the table that is posted above i am still under the weight maximum fully loaded
2010 6.4
Oxford White with Stone interior
Windows limo tinted and medium on windshield
H&S mini maxx with full delete
Bilstein leveling coils
Fuel hostage wheels (18 inch)
325/65/18 pirelli tires
2010 Stroker is offline
post #12 of 22 Old 10-03-2011, 01:17 PM
INJEKTER1's Avatar
Quoted: 4 Post(s)
max wt for a F250 is 12,500.... you said you would be at 15,000......not exactly below the limit.....as far as towing goes....the biggest factor is the size and weight of the tow vehicle verses the size and weight of whats being towed..... when i first purchaced my current trailer, empty 7200lbs.i brought it home with my 2002 v8 explorer with a tow rating of 7400 . i thought no problem im under the limit..... if you could have only seen me towing home that 32 foot trailer, getting pushed past stop signs trying to stop....your truck will tow that trailer, but not safely, when chit hits the fan and someone does some crazy crap in front of you i hope you dont become part of the accident... good luck man.
08 F350 MINI MAXX,5"FLO-PRO DPF DELETE, AFE INTAKE,HID'S,BFG A/T'S ON 20" BMF NOVAKANES,TIMBREMS,BLACKED OUT BUMPERS GRILL,STEPS RACING STRIPES,PAINTED HEADLIGHTS ,FABTECH LEVELD,RCX DUAL STABILISERS
INJEKTER1 is offline
post #13 of 22 Old 10-03-2011, 01:49 PM
44magnum's Avatar
Quoted: 2 Post(s)
CDL requirements per state You need to look at your gvwr and your trailers gvwr and then you need to figure out your tounge weight and make sure your not over your trucks or trailers gvwr. I tow a 38' triple axle cargo trailer and while it has triple 6k axles its gvwr is 12k and my truck is rated at 10K so I dont need a CDL as I'm under the combined gvwr of 26K. I have airbags on the rear and I haven't experienced any tail wagging even in heavy wind. And I have driven a semi with a 22' grain trailer and a semi with a 42' grain trailer and my truck fully loaded with a total weight around 22k still stops better than most semis. So I dont really know what these guys are talking about. That being said obviously a 450 would do the job better but your 250 will do it just fine.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #14 of 22 Old 10-03-2011, 01:59 PM
I tow a 43 foot Cyclone toyhauler all the time (but I have an F-350 DRW). As for using an F-250, you can do it, just get some airbags and make sure your tires are up for it (E-load range in good condtion at least). Also make sure you have a good trailer brake controller (either the factory one or one that actually senses brake fluid pressure and adjusts trailer brakes accordly. I suggest Maxbrake if you don't have the factory one). Oh, and if you have 3:55 gears , you might want to swap those out for something a little lower (I have 4:30's and they make getting started from a dead stop and pulling uphill real nice, and my trailer weighs at least 18K when loaded)
Antonm is offline
post #15 of 22 Old 10-03-2011, 03:05 PM Thread Starter
thanks for the imput it seems like ppl just like to tell you your wrong sometimes. i think i will be fine as well and i know ford rates the truck lower then what it can really handle. they have to for lawyer reasons.
2010 6.4
post #16 of 22 Old 10-03-2011, 03:17 PM
majek5's Avatar
If you are gonna do what you want anyway, why waste everyones time asking questions that you already have "your" answers to? It has been stated how to legally tow that beast. Good luck and be safe.
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #17 of 22 Old 10-05-2011, 01:58 PM
I would also suggest a dually, especially with a 40 foot trailer. If you do alot of highway driving a dually is a world of difference.
2009 f250
H0USE is offline
post #18 of 22 Old 10-06-2011, 10:07 AM
1fastTRX's Avatar
Well since it's a 40 footer its defintiely a 5th wheel. 16,400 max weight for 5th wheel, but gcwr is 23,000. I know the 2008-2010 trucks are heavy so lets call it 8,500 lbs... 23,000 - 8,500 = 14,500 max 5th wheel size (without getting into tongue weight and so forth). Your insurance could deny a claim if something ever happened and they proved you were negligent in towing over the trucks legal limit.
You already made the purchase and ideally you would want to step up to a dually, but that's been stated. If the toyhauler doesn't have brakes on each axle then that would be a big plus in stopping that thing. Pulling it isn't an issue. Gears may help your tranny in the long run (maybe 4.10s). Airbags are going to be a must (plus riding level won't blind oncoming traffic). Make sure you have a high enough load range on the trucks tires (E definitely; a blow out would suck especially considering its a SRW). Maybe consider a brake upgrade (not necessarily big brake kit, but good rotors, pads, steel braided brake lines)
You said mostly flat towing and carrying a sandrail. Are you in Cali going to glamis mostly?
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #19 of 22 Old 11-03-2011, 01:41 PM
Dazed and Confused!!!
08 F250, 4x2, 6.4, long bed; looking at 5th wheel toy haulers.
Saw the following in a previous post:
Originally Posted by Based_on_2008_model
F-250 16,400 lbs. 5th-Wheel Towing 12,500 lbs. Conventional Towing 3170 lbs. Payload 23,000 lbs. GCWR 10,000 lbs. GVWR 6000 lbs. Front GAWR
The Tire and Loading Information sticker in my truck says: "Combined weight of occupants and cargo should never exceed 2430 pounds"
So, is my "payload" 3170lb or 2430lb? Is the Tire and Loading Information sticker number lower because of the tires (E rated)? My concern is fifth wheel "hitch weight".
cenfl is offline
post #20 of 22 Old 11-03-2011, 03:51 PM
I am going to go off of the idea that you don't want to sell your truck and get a different one. It seems that is the bulk of the advice on this topic, which in most cases doesn't make too much sense.
I have always viewed things with a few assumptions.
Depending on the topic manufacturers specs and limits are highly conservative in regards to what the PARTS can handle, the driver is another story, only you can answer this
Determine your trip length and frequency, if its not much then work with what you have
I would probably get air bags and a quality rear sway bar for handling and to keep even pressure on the tires as you are turning or stopping
get a high end brake controller, some think that the prodigy 2 is great, I think its ok, like someone else posted brake line pressure sensing would be better, not going to beat the factory TBC though
good NEWER e rated tires, I say newer because had an incident where a seemingly good tire destroyed the rear quarter panel when it blew and they weren't even maxed out on weight
Beyond that its all about how much risk you are willing to take. If you have a lot of towing experience then have fun, if not then you are definately taking a chance that IF things get out of hand you will be ill prepared to control the situation, and if your truck is a shortbed then you just about doubled the chance that a hairly situation could go for the worse
Good luck
2015 F350 Platinum CCSB SRW
100% stock
SOLD: Black 08 F350 FX4
Spartan tuned
MBPR DP Back straight pipe
20' XD Hoss's
325/60 Duratracs
Leveled
chinaman is offline
