Spartan help please
just put the dpf delete pie on and spartan tune on last night now im told u have to do a certain driving procedure in order to make transmission learn spartan? anyone know???
What tune are you running?
if your running the normal 210 and under tunes it shifts like stock and there is no need to do a trans relearn, other wise it just helps the trans shift better faster. If you don't do a trans relearn it takes like a 100 miles or so to shift better.
there is a sticky post at the top of the 6.4 performance section that explains how to do a tranny relearn.
Just to clarify.....when you install a tune on a stock truck, the trans memory is wiped clean. The series of accelerations and stops on a high power setting are meant to build memory on the transmission control module in such a way that the trans gets used to the power level and desired shift points of the new beast motor. If you wish to do a relearn, you need to return you truck pcm to stock, then reinstall the tune. It is the coming from stock to tune that wipes the memory clean.
im running the 275 tune
As stated above read the sticky in the perf. sec.! Follow thoose intructions you'll be set!!!!
have u actually tried adding the 1/2 a quart not gunna lie that kinda scares me
I ran mine close to a qt over full with no probs! I just did the 11b23 reflash from ford & switched to the v2 programming from spartan trans, fluid at the propper level now & no probs at all! For the most part running a trans over full will not hurt anything, if it gets hot & there's to much fluid it might puke a little fluid out of the vent but thats it!!!
| Tags |
| dpf, spartan, tune, tuner |
