Need specifications payload/towing - Ford Powerstroke Diesel Forum
Old 08-23-2007, 02:29 PM
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Can someone provide for me the max payload capacity of a 6.4 equipped F250, F350 and F450 pickups? I know the 450 can tow 24,500 max, but I need to know it's payload, as well as both towing and payload capacities for both the 250 and 350. Thanks fellerz.......
Old 08-23-2007, 06:38 PM
My door sticker says payload 2529 lb.
Might be some differences depending on tires installed at the factory and vehicle weight.
Be sure to check the stickers when you look at them.
Old 08-23-2007, 10:12 PM
Ah man, there are more 08 owners on here than THIS!!!!!!!
Old 08-23-2007, 10:23 PM
Ford Vehicles: Super Duty - Specifications
go to payload package
Old 08-28-2007, 06:02 PM
Thumbs up
If you have F450 you can pull 24,000lbs with 4.88 and tow boss rear and you can get 4.3 rear pull 20,000lbs with it. Plus if you buy 4.88 rear end you will turn over 2600rpms at 70mph and turn 2200 rpm at 70mph so if going pull with 4.88 rear better use all the time other wise you will get bad mpg's with it. I get about 8.0mpg pulling mt trailer. payload is 5720lbs with 4x4 and 6120 with 4x2 and F250 with CC SB 2410 with 6.4L PSD manual tran 4X4 and F350 SRW CC SB 6.4L PSD MANUAL 3670 DRW 5220LBS 4X2 AND 4X4 4960 towing 4x4 auto 15,200LBS 4.10 rear end and 4.3 rear end 17,700LBS. That is just some them.
Old 04-11-2009, 05:57 PM
payload
Goto the dealer and ask for the truck source book, every answer is in there. No where else. There are so many configurations possible. The source book is your only source.
Good luck
Rob
Old 04-11-2009, 06:10 PM
say no to rolling coal
Looking in to an 08 or 09 Adam?
