Ok guys convince on doing this mod - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-17-2011, 03:52 PM Thread Starter
jac97psd's Avatar
Ok guys convince me on doing this mod
I've been going back and forth ordering the EGR delete with CFM. Money is not the problem but just taking time for me to put it on is what I'm debating about. I know it's worth the money but spending a whole weekend doing this project is it worth my time like that?
2010 F-350 CC SRW LongBed 4X4
Spartan tunes, 5 inch Flo-Pro w/ DPF Delete, AFE stage 2 CAI, Cold side piping, 4 inch down pipe, Rudy's EGR delete, Air Dog II
jac97psd is offline
post #2 of 18 Old 09-17-2011, 04:05 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
If money is not a problem, let a shop do it. Takes about 9 hours to remove the EGR coolers.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #3 of 18 Old 09-17-2011, 04:07 PM Thread Starter
jac97psd's Avatar
Eh...I've done everything else to my truck and I know this can be done in the drive way. I don't like to pay for labor. So if I buy it I'll be doing it.
jac97psd is offline
post #4 of 18 Old 09-17-2011, 04:16 PM
I just finished an EGR delete earlier today (the flo-pro kit from PTP). I did it in my driveway with basic hand tools and it took me about six hours start to finish. Was it worth it....only time will tell. Overall I didn't think it was all that hard, and I'd do it again.
Antonm is offline
post #5 of 18 Old 09-17-2011, 04:29 PM Thread Starter
jac97psd's Avatar
Thanks for the info. Are all EGR delete and CFM kits pretty much the same? I was planning on buying from Rudy's.
jac97psd is offline
post #6 of 18 Old 09-17-2011, 05:28 PM
They are all pretty much the same. I went with the Pro-Flow kit from PTP based on price difference. The kit from Rudy's with CFM elbow is $500, the Pro-Flow kit was $400 (and PTP had free shipping on orders over $50 special going on). I'm sure pretty much anything from Rudy's is going to be a quality part, they were the ones I was orginally going to buy from but I just couldn't see what the extra $100 was getting me, so I went with Pro-Flow.
Antonm is offline
post #7 of 18 Old 09-17-2011, 06:12 PM
sanman28's Avatar
I too did the pro flo kit in my garage. It is not a complicated install......but it is VERY cramped in there. So prepare yourself to cut some hands and knuckles. I had fitment problems with all three block plates. I had to enlarge the holes in my exhaust flange b/c the block plate was a little tight, and its the threaded part. Screws would not line up. My coolant plug holes had to be enlarged too b/c the srews holding them them wouldnt hit the hole straight and they have to. Pain in the azz to do them too. No room to turn a ratchet.
2010 CCSB FX4. Mini Maxx/Gearhead, Deletes, H11 Studs, Up-pipes, 4" DP, 5" Back, CAC, Elbow, CCV, CAI, Custom Heads, Elite Transmission
FBHO
sanman28 is offline
post #8 of 18 Old 09-17-2011, 06:20 PM
Yeah I have the same view too, I'd rather do the work myself. I really want to do this mod, but I'm only pushing a 250 spartan tune so I dont think its necessary yet. Let us know how it goes and what you think about the part because I know a lot of guys on here want to do it!!
13F --U.S. Army Retired
2010 F350 KingRanch (with some options
)Super Duty 6.4 CC/SWB Spartan delete w/250, AirDog2 D-165, Full EGR Delete, CAI, and sweet exhaust :thumb
strivingfirst is offline
post #9 of 18 Old 09-17-2011, 06:43 PM
I guess they've change the kit a little then. I did it earlier today ( 9/17/2011 ) and didn't have any fitment issues. I thought the instructions lacked a little, they had a few spelling and punctuation errors which "could" lead to confusion (and if I'm catching that then something’s wrong because I am no English major). I also thought the instructions put some of the steps out of logical order (like they had you remove a hose , then do four more steps then go back and plug the hole you removed the hose from four steps ago, things like that happened several times). And lastly the instructions said to cut a bunch of stuff, don't know why, it all unbolts fine. I did the delete without cutting a damn thing so if I ever need to put it back to stock, I can. Overall I like the Pro-Flow kit. And if you were to follow the instructions, step by step, you would get the job done, I just think they could be better (a lot better actually). Overall I'll give the Pro-Flow EGR delete kit a 9 out of 10 and PTP a 10 out of 10.
Antonm is offline
post #10 of 18 Old 09-17-2011, 08:48 PM
Quoted: 20 Post(s)
I like Elite's kit. It's a bit more expensive than the Flo Pro kit. They're CFM is powdercoated and tapped but then you have to buy the blockoff plates. After everything is said and done, you're looking at $500.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
