7.3 being funny - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-20-2007, 09:20 AM Thread Starter
7.3 being funny
I have a late 99 7.3. I fired it up this morning and it sounded like a johnny pop. Like it was only running on a couple jugs. I pluged my scanner in it and got these codes;
p1294 Injector high side open
p1249 wastegate control valve performance
p1316 inj driver module codes detected
p0478 exhaust pressure control valve circut high imput
p0470 exhaust pressure sensor circut malfunctiop0236 turbo/super boost sensor A ckt range/perf
p1211 inj crontrol press beyond desired
I wrote the codes down then wiped them out. it ran fine for 5 min then it did it again. now i get this code; 1294 inj highside open bank 2. Anyone know whats going on with this?
sleeperstroker is offline
post #2 of 7 Old 08-20-2007, 10:08 AM
ADMIN AND TECH
SCUFFY828's Avatar
remove the drivers side valve cover and reconect short harness under valve cover , clear system and see what happens
ITS STOCK
SCUFFY828 is offline
post #3 of 7 Old 08-20-2007, 10:13 AM Thread Starter
thanks. ill give it a shot ADAM
post #4 of 7 Old 08-20-2007, 05:26 PM
sttstroke's Avatar
thats exactly what it is just done it.
sttstroke is offline
post #5 of 7 Old 08-20-2007, 08:19 PM Thread Starter
Its all better. Thats what it was.
thanks!
post #6 of 7 Old 09-07-2007, 04:37 PM
chrispaine's Avatar
i am getting P1249 I cant seem to find anymore info on it. any ideas? thanks.
chrispaine is offline
post #7 of 7 Old 09-07-2007, 04:41 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Check the green and red line on the wastegate solenoid and make sure they aren't leaking.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
