Help won't start
I turned off key while downloading a tune from mini max, and the lock is flashing on the dash. The truck won't crank over or do anything. The mini max tuner won't do anything.. Please any help be appreciated. Dealership won't open till tue.
try contacting H&S and see if they can get you a recovery stock file. I don't know why you turned your key off before the tune load was finished. and with it being labor day weekend you probably wont be able to get anything solved until tuesday. good luck
my truck was doing this recently, i wasnt uploading a tune to the truck but it wouldnt start- come to find out unplugging the batteries and resetting everything fixed it, started right up after, try that, also check your obdII port fuse
This will not work for his issue. He turned his truck off while loading a tune so his computer doesn't have a program on it to control the truck. And he doesn't need to do anything with the obdII fuse since there isn't a problem with it. His issue was operator error and needs to contact H&S to get a recovery file. Good luck to the OP
