Water separator filter Handle Broke Need help ASAP
Okay I was draining my water separator, and I drained it just fine, but then later I looked under the truck and there was a wet spot, so I climbed under the truck to take a look, and sure enough the leak was coming from the separator filter spout, so I opened it up and the closed it, and it was still leaking, so I went to open it again, and then the yellow handle broke off, so Now how do I get the valve to shut off.
water separator filter handle broke Need help ASAP
Turns out that the spout from which you drain the filter from is conected to the handle valve. So I turned the spout so that the valve is shut, but now there is a constant drip when the truck is off. Any thoughts?
try seeing if you can manually close the valve by removing the front cover or by sticking a scribe in there. if not then your only option is to wait till ford opens up to buy a replacement kit.
Thanks I will have to wait tell Tuesday and get the kit from Ford.
