warranty questions
Its there a way to check if my warranty is still good, I recently purchased the truck, and it hazing out the exhaust, dpf related I think, and has a small coolant leak, also is there a copay on warranty work? Thanks
power train is 10/100000 I believe take her in
Wanted to see if the previous owned voided it or something, I have some other warranty from a outside company too they made me get when I got the truck
Call the outside company and check to see if their warranty is still good. The original warranty is 100000 or 5 years from original purchase date, so you'd have to check with Ford for that.
The outside company is not fun to deal with, but it has 2 years left, if ford wont cover it, ill have the other one do it
Took it in today, the service rep said everything should be covered but the radiator, so the outside company should take care of it, unless the leak was a motor caused issue
So, the bedplate is leaking and they are going to fix that, but the coolant leak is coming from the degas bottle which isn't covered by ford or the other company, trying to work on that right now. But the exhaust is overly sooty and was wet.... don't know what that means
