Linked F450
Interesting read I thought from another forum I look at.
http://www.pirate4x4.com/forum/showthread.php?t=581470 |
That was interesting, I'm not bashing you guys fat bottomed trucks, fact is my next new one will be a crew cab F-350 Dually.
But, the dually bedded trucks do not have the same spring packs, hence load capicty as a cab & chassis trucks, they are ok for pulling large loads, but for hauling they cant come close to thier cab & chassis counterparts. This guy should have bought a F-550 cab & chassis and put a dually bed on it, would have been cheeper in the long run |
When they rate the payload it's not for something hanging off of the back end.
It needs a slide in camper rating which is going to be considerably less than the payload. The truck is overloaded according to the camper rating. A truck camper is designed to be self contained. By the time you add everything to a 4k camper you need an F550 specifically equiped for truck campers. You could add a set of timbrens (rubber springs) to it. I put a set on my 1500 and it tows my 5th wheel level. Rides good as well. When it's not loaded it rides the same as without the timbrens. I have seen 350's that were more than 3000 lb over the GVWR with a truck camper. They were flipping over in Colorado. Last edited by DavidPhillips; 08-17-2007 at 06:43 PM. |
this guy should think about getting the rear leaf spring kit that they make for tow trucks.
I think it's just too much of a camper.
nothing you can do short of another truck. if it's not over the gvwr add 600lb to the front. still should have a camper ratinng actually. Last edited by DavidPhillips; 08-20-2007 at 05:15 PM. |
