Power steering going out... - Ford Powerstroke Diesel Forum
Old 08-14-2011, 12:22 PM
Sometimes my power steering goes out when braking. Started mostly when pulling a load. Lately has begun doing it without a load. Power brakes go out at the same time. (it's a great feeling) Just topped off the brake fluid. Any other suggestions?
Old 08-14-2011, 03:39 PM
SOMETHING screwy starting with my steering and brakes as well....is it making a wurring /humming noise below the dash?
Old 08-14-2011, 04:50 PM
Send a message via AIM to eric.davis
I believe there is a TSB out for this. One is for Power Steering - Fluid Discolored, Noise or High Effort
and the other is
Steering/Brakes - Brake Pedal Kick-Back/Grabbing
Old 08-14-2011, 06:00 PM
mine crapped out on my 08 twice. it would hardly steer and i had to put all my effort into the pedal to stop. get that power steering fixed asap before it gts worse. its actually a fairly common issue
Old 08-14-2011, 06:51 PM
and the other is
where do you find this TSB?
Old 08-15-2011, 03:05 AM
From the other forums in the tech sections
Old 08-15-2011, 06:15 AM
thx
Old 08-15-2011, 04:05 PM
check your power steering fluid...service mgr told me to over fill it...i checked and it was below the minimum....seems to effect your breaking as well.... all my issues have now vanished
Old 08-16-2011, 05:14 AM
Good info in case that ever happens. Thanks
