Good day ORG, Coolant question for you. Who has checked the coolant level for the PH Balance? What do I need to do this and how often do you check your ph level? What is the proper PH Balance Level? I would like to do this and not have to take it back to the dealer and have it checked. Thanks
i am also curious about this. I think we need to check nitrates. I think i remember reading that they sell the test strips at napa.
I take it that the test strips would come with directions on where it needs to be or do you have to find that information else where? I am also curious about this.
Maybe we will get someone to chime in that does the testing there self's before to long.
Need to test the nitrates. You can buy the strips at Napa. You want to get a reading above 800 ppm if I recall correctly, test the coolant before it gets hot.
Cool, Thanks. I will be going to the local NAPA Saturday to pick some up and i will repost my findings.
Procedures for Ford Rotunda #328-00001
1-800-ROTUNDA (768-8632) ....$5.67 for a pack of 4....includes mail.sold by ACUSTRIP denville nj....very clear instructions....these things have a shelf life so you dont need too many.
She was apologetic, but I'm not 100% sure she knew what she was talking about. I told her thanks, but no thanks.I then called ACUSTRIP at 973-299-8237 and the lady there knew right away what I wanted. She took my info and $5.67 later they are in the mail.
Napa sells the kit for a lot of strips, probably 30-50, I forget, its sitting in my shop, for 25 dollars I believe. PH should be around 8.0, Nitrates should be 800-1200ppm, and coolant concentrations should be at 50% (freeze protection at -34*f). Make sure you look at the expiration date before you buy the strips...the first time I bought them at Napa they were a month away from expiring....
Last edited by rt_hawk; 03-10-2013 at 10:16 AM. Reason: hit the wrong number for pH |
So is the PH balance universal for all brands and kinds of coolant? |
