HFCM - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-27-2011, 08:04 AM Thread Starter
dubb75's Avatar
HFCM
Hi hope i don't sound like a dork I'm a little new to the diesel truck, I have herd a lot about draining the HFCM what is that,and how do i do that. Also concerned about weather or not my truck is a job 1 or 2 and so on a lot of issues with job 1. build date is 02/08 thanks for any help.
dubb75 is offline
post #2 of 13 Old 07-27-2011, 09:24 AM
t613's Avatar
You are definitely past the job 1 run, could be a 2 or 3, I forget the dates of job runs.
The HFCM sits inside the frame rail, just about under the driver's seat. There is a little yellow valve that you can open to drain any water out of the system. A good idea to do it every month or so. I use a cut-off soda bottle (clear) to catch the drained fluid. The fuel should look similar to Mountain Dew, any water will show up at the bottom, usually looks whitish. You should only need to drain it until solid fuel comes out, I usually drain 3/4 cup and that does it.
Apparently these 6.4's don't like ANYTHING other than pure ULSD. A good idea to change the fuel filters every 10k miles too, the book says 20k, but it's up to you.
Have fun with it!
Tim
2008 F-250 6.4L PSD, SC, short bed, 4x4 auto, Toreador red. Huntsville motor, all stock except for Injen/Amsoil intake.
t613 is offline
post #3 of 13 Old 07-27-2011, 10:22 AM Thread Starter
dubb75's Avatar
Thank you for your help!
dubb75 is offline
post #4 of 13 Old 07-27-2011, 10:44 AM Thread Starter
dubb75's Avatar
I opened the lever and nothing came out, even tried with it in idle.
dubb75 is offline
post #5 of 13 Old 07-27-2011, 10:52 AM
XPLOSIV's Avatar
Sounds like it's plugged up. How many miles are on the truck? When was the last time it was drained? When was the last time the fuel filters were replaced.
08 F450 CCLB 4.30's
Spartan, Pure Performance Custom 3", Toyo M608Z, MBRP, FloPro, Banks, Volant, Mishimoto, Dieselsite, LineX, Reese 30k
XPLOSIV is offline
post #6 of 13 Old 07-27-2011, 11:08 AM
Quoted: 6 Post(s)
yea i think it sould drain water first then fuel should come out maybe the drain is clogged
a2elvis is offline
post #7 of 13 Old 07-27-2011, 11:13 AM
t613's Avatar
Mine did that too at first. With the key on,it finally pressured through and has drained well ever since. I don't know if sticking something up the hole with the valve opened would work. It definitely needs to be drained periodically.
It may be time to open the filter housing and clean the drain (and change the filter while you're at it).
Good luck and let us know how you made out.
Tim
t613 is offline
post #8 of 13 Old 07-27-2011, 11:14 AM Thread Starter
dubb75's Avatar
I have 18,000 miles, put on 5,000 since i bought at dealership.
dubb75 is offline
post #9 of 13 Old 07-28-2011, 07:47 AM
theplumbingmedic's Avatar
I would bring it back to the dealer it should be their problem. Good luck
theplumbingmedic is offline
post #10 of 13 Old 07-28-2011, 10:50 AM
Agreed. Make the dealer clean it out and drain the water. I make sure that they drain the water separator every time that I change O&F just for documentation. Fuel filters every 10k miles as well.
BlueF350 is offline
