Dieselsite Coolant and Trans Filter Systems help - Ford Powerstroke Diesel Forum
Old 07-20-2011, 04:49 AM
Dont Mess With Texas!
Any of you 6.4 guys have the Dieselsite coolant filter system intalled in your truck? can you snap a pic of the mounting location? also how hard was it to install, and do you feel it was a worthwhile mod for the price?
also the tranny system same thing, im more interested in the coolant filtration.
and can i still run ford gold until warranty is up with this filtration system or do i have to use an ELC?
thanks in advance for the help guys
Old 07-20-2011, 09:30 AM
Ditto I have the same request? And questions
Old 07-20-2011, 10:19 AM
I have both the coolant filter and the tranny filter. They seem to work well. THey are good quality and easy to install. I will cut the coolant filter open and post a picture after i change it. I will try and get some pictures soon.
Old 07-20-2011, 10:21 AM
Where did you mount it?
Old 07-20-2011, 10:22 AM
i mounted both on the passenger side frame rail. One is right next to the other. THe coolant filter is mounted horizontally as per the instructions.
Old 07-20-2011, 10:28 AM
when you get a sec if you could snap a pic i would appreciate that
TIA
Old 07-20-2011, 10:29 AM
will do! I recommend them as they are good quality. Next up are the dieselsite intercooler boots.
Old 07-20-2011, 04:30 PM
I too have both dieselsite trans and coolant filters. Both are high quality at a reasonable price. I also mounted both of mine on the passenger side frame rail (except I didn't drill any holes in the frame to do it and I also changed around some fittings to make the mounting more to my likeing). I highly recommend both filter setups and dieselsite as a whole.
Old 07-20-2011, 04:52 PM
I was really impressed with the Dieslsite coolant filter setup. I won't be doing the transmission filter but I do highly recommend the coolant setup.
I don't have any pics but I can tell you that it is mounted on the outside of the frame rail right below the passenger door.
Old 07-20-2011, 05:40 PM
Hey 08 f250 where at in corpus are u? I'm out here in calallen not to many diesel junkies I know around here,
