6.4 stock egt probe location?
just curious as to where it's located at...just deleted a customer's 6.4(a surprisingly easy job...both the 6.4 and 6.7 strokers are just stupid easy to delete compared to the Cummins) and installed a mini maxx in it, and it had pyro 1 as the first gauge on the gauge screen from the factory...and it actually showed readings that seemed true...but it hit the 1250 degree defuel i set for him on a half throttle run at about 80 on the mild tune(good god these things are fast and the trannys hit hard) so anyway, i'm just wonderin what would be a good temp to set it at?
