fuel filter change question....
changed the fuel filters last night. trying to figure out what i am doing wrong since i cant avoid the diesel bath. i opened the drain on the rail filter, then removed and changed the top filter, the rail filter never stopped draining, it filled a 2 gallon bucket then went to a slow drip- i pulled the rail filter and got covered with a constent flow of fuel. truck had 3/4 tank. last time truck had 1/4 tank i did the top filter and didnt put lid back on and drained the rail filter- it never stopped draining completely and i took a bath. what am i missing or doing wrong?
Watch this:
Youtube - F250 Fuel Filter change: |
You need to pull the top first or the fuel will siphon from the tank.
ok- thanks cause it definatelywas pulling from the tank.
are these the proper steps then? 1. remove top filter 2. drain rail filter 3. remove-replace rail filter 4. replace top filter |
After the job is done: Prep the fuel lines by cycling the ignition about 6-8 times afterwards, without starting, for about 6 seconds each time. Started first try. |
Just opening the top cap will prevent the siphon. So the first step is open the top cap.
