F250 vs. F350 what parts are different? - Ford Powerstroke Diesel Forum
Old 07-13-2011, 12:19 AM
Guys,
What parts are different on the F250 than F350 in 2008?
- f/r springs
- f/r shocks?
- side badges?
- available gear ratios?
Thx,
M
Old 07-13-2011, 06:18 AM
springs and rear axles and the 350 might still have offered a 4:10....2008 was first time for 3:55 since the 1987 f350...i think.
Old 07-13-2011, 07:03 AM
What rear end does the F250 have?
What rear end does the F350 have?
Old 07-13-2011, 07:39 AM
Please don't quote me on it, but I had always heard the big difference is the 4" spacer block in the rear spring stack of the 350, as opposed to the 250's 2", and the addition of a helper spring on the 350 rear springs.
I had priced out (built online) two similar trucks, one 250, the other 350, same options, back in '08. The price difference between the two was $200 more for the 350. I can't imagine they are truly that much different for the $200 difference.
Anyone here know for sure?
Tim
Old 07-13-2011, 08:09 AM
taller rear block in the 350. not sure if still true as new as 08 but I believe dana 80 instead of dana 60 in the rear. Not sure what else
Old 07-13-2011, 08:29 AM
They offered 3.55's in the OBS(1997) trucks, only got rid of it in the SD's. Unless you are refering to 350's only, then you may be correct.
Tim
The rear block is true. The 250 and 350 use the same spring codes, just depends on the setup.
Really all you pay for is GVWR and GCWR, SRW 3/4 and 1 tons are the same.
SD 250's have never had a 60 rear, they had a 70.
Old 07-13-2011, 08:33 AM
I believe you are wrong with the SRW being the same GVWR. Cause my 350 is rated at 11,500. I don't think a 250 is rated that high.
Old 07-13-2011, 08:37 AM
No I mean physically they are the same truck. The difference you pay in price is for a higher GVWR and GCWR in the 350.
Old 07-13-2011, 08:40 AM
Gotcha.
Old 07-13-2011, 08:44 AM
Gotcha.
And your GVWR is 11500 in your SRW? Thats cool. I've always though about buying a newer f450 for the GVWR and GCWR with a shot drivetrain so I can just drop a 7.3 and zf6 in it so I can have a great tow pig I can still work on
