avoid all '08 models?
I am looking for a newer used work truck, want a '08-10 superduty. Of all the problem threads I read, almost every one starts off with the '08 truck. Should I just avoid the p.o.s. and safe myself the headache?
Not all 08's are bad trucks. There are several thousands problem free 08 trucks out there. But to play it safe yes an 09-10 would be your safe bet.
Get a '08 with higher mileage that have had the problems fixed or have been broke in.
![]() Main problems have pretty much all been taking care of with TSB's. Things like radiator repairs, venturi T's, injectors, etc.. By far the most common issue is the radiator. Otherwise, the '08's are as solid as the '09 and '10's. |
Actually, the 08 MY began in March of '07. Anyway, my Job 1 08 (4/07 build) has 61,000 miles on it and very few issues. Yes, I did get the extended warranty to 75k miles. I'll get a new truck in 2013 when the MY 14 trucks are launched. Till then, I'll be careful and hopefully lucky.
i actually just saw one at a local consignment shop by my house, 08 f350 same color as my truck below but lariat with 18's ranch hand front, and rear replacement, headache rack, it was a hot shot truck has 212,000 miles went for a drive in it, ran like a champ never been tuned all stock, only problem is the guy wants $27,500 for it i told him i would take it off his hands for $20k but it is a nice truckQuote:
I have a EARLY job 1 and I did buy it used with 40k on it but it has 85k on it now and I have had the Rad replaced and the Charge air cooler replaced (paint peeling off) I had an A/C door blend actuator behind the dash replaced (weird noise) I had the steering wheel replaced (not trucks fault, milking warranty), shift lever replaced (tow/haul button stopped working), digital climate control unit replaced (once again nothing was wrong with it just had a TSB on it and milking warranty), upper rad hose (leaking) and I think thats about it. I have fought some front end issues but a lot of that was tires and leveling kit. I got new tie rod ends, new drag link, and new track bar. Truck has never not fired right up though. Just keep fluids and filters changed. Oil every 4k for me and fuel every 12k. Trans every 30k. It will pass everything but a gas station ;-) Delete the DPF
The ones that have the most issues are the 8/07 and earlier which are the job one trucks they had the most issues. 8/07-12/08 is job 2 and they are really good and job 3 01/08-up and are just fine as well. Hope this helps
