NO CRUZ CODE P0703 BRAKE SWITCH B - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-05-2011, 10:11 AM Thread Starter
laynlow transport's Avatar
any one no what switch i should change got 2 dtc p0703 and p2125a ?????
2008 F350 fx4
S&B intake
8" fab tech
pro comp trac bars
fab tech radias arms
5" turbo back
7" stack
coolant filter
air dog 2
ARP STUDS
EGR delete
CCV filter
Street Diesel big intake and cooler pipe
H&S MINI MAXX 300 tunne
2 10" kicker subs
ALPINE NAV
HID head and fog lights
RECON lights all around
AMP POWER STEPS
20x12 FUEL NUTZ Wheels 38x15.5 20 Mtz
laynlow transport is offline
post #2 of 5 Old 07-05-2011, 06:43 PM
j21black's Avatar
Quoted: 15 Post(s)
Had the same issue this weekend. It happened after I had applied the parking brake.
I found where the switches were going bad casuing the computer to think the brake was engaged, thus not allowing the cruise control to engage.
I just wiggled the connector coming of the brake pedal and the connector under the master cyclinder and drove 600miles home with the cruise control engaged.
j21black is offline
post #3 of 5 Old 07-06-2011, 07:57 PM Thread Starter
i changed the front one under master cyl today seems to work good
2008 F350 fx4
S&B intake
8" fab tech
pro comp trac bars
5" turbo back
7" stack
coolant filter
air dog 2
ARP STUDS
EGR delete
CCV filter
2 10" kicker subs
ALPINE NAV
AMP POWER STEPS
post #4 of 5 Old 10-10-2011, 05:03 PM
Haulin
No Cruise Code P0703 Brake switch B
I have changed both of the sensors on the master brake cylinder, and I still have no cruise, I even Called H&S, I installed the new update, and then went back to stock, to make sure that it wasn't the software, so I went back to stock and I still had the problem. Any thought on what the problem is as I will be driving to Santa Fe New Mexico, which is a 12 hour drive for me give or take a little bit, and I would like to have my Cruise Control working.
BigBlue_08 is offline
post #5 of 5 Old 10-13-2011, 05:11 PM Thread Starter
any luck yet ????
2008 F350 fx4
S&B intake
8" fab tech
pro comp trac bars
5" turbo back
7" stack
coolant filter
air dog 2
ARP STUDS
EGR delete
CCV filter
2 10" kicker subs
ALPINE NAV
AMP POWER STEPS
