Do i need E rated tires?
I'm gonna get some new tires soon and was wondering if i needed E rated or 10 ply tires like the place told me? I got a 2008 f350 SRW and the biggest thing i tow is a 2 place quad trailer so i wasn't sure the price is alot higher for the 10 ply.
Yes you need E rated or a similarly spec'd D rated tire
these trucks are supposed to have E rated tires, if your not towing anything you never exceed the capacity of D rated tires so you would be fine. But latter if you get any type of heavy trailer, you'll exceed the D's real quick and wish you would of gotten Es
i've got d's on my truck... not wearing well on one tire. seems to be the one I always break loose....
you can run D rated tires but you will not be able to A haul heavy load and B you will burn through a set of tires alot faster with D rated
E rated wear better and you will get better mileage with the higher PSI too
thanks for the input E it is. Anyone have any input on cooper zeon ltz's i like the way they look. my buddy really likes his terra grapplers tho.
Also if you run D rated you will run a low tire light as well.
You need tires that match the OEM or better. Weight rating is important... and if you had a blowout and got in an accident as a result... lots of lawsuit coming your way.... not to mention the insurance company(s) might blame you or give you a hard time.
