license plate renewal - Ford Powerstroke Diesel Forum
Old 06-16-2011, 05:39 AM
After getting my trucks plate form the dealer, after buying it in Feb. I get the plate in and it expires this month, I asked them if the only issued a 6 month plate or wtf. Well They are telling me that In Louisiana, the plate is only good for 1 year because of the weight of the truck, This is an 08 250, I just renewed my 99 250 and its a 4 yr. tag. How is it in other states? both trucks are close to the same weight. i don't understand the new Law.
Old 06-16-2011, 05:46 AM
The Silent Service
Depends on how the laws in LA are written, there's a few states that over XXK GVWR it takes commercial plates, which follow different rules. For example VA my 13K GVWR gets truck plates, when I get transferred to CT I must get Commerical plates. (thier limit is 10K GVWR). There is a huge difference in GVWR's between the '99 and '08, although the curb wieghts remained about the same.
Old 06-16-2011, 05:55 AM
IS there that much difference in weight from a 99 F-250 to an 08 F-250 ? I will find out the reason whe i go to the Dmv tomorrow?
Old 06-16-2011, 09:05 AM
The Silent Service
The '08 should have a higher payload, and should have a higher GVWR. That could be what's putting you in a different class of registration.
Old 06-16-2011, 09:47 AM
NOT sure but i think i had seen the sticker on the door on the 99 that the gvw was 8800 the 08 said 8900 maybe not. i'll definetly look again before i go an ask them whats the difference. So my payload on the 08 is higher than the 99??
Old 06-16-2011, 11:31 AM
f250 ratings
the 99 gvw is 8800......the 2008 is 10,000. your pay load depends on the config of a truck...a reg cab 2 wheel drive will carry a bigger payload compared to a 4door 4 wheel drive.....but whats that got to do with your tags running out after 6 mos? if you bought out the door tax and tags price and they only gave you 6 months on the tags you were cheated.
Old 06-16-2011, 11:39 AM
I am taking this is a used truck seeing it’s a 2008.
In Arizona purchasing a new truck one can purchase up to 5 years seeing you do not have to go to emissions testing the first 5 years.
Now if one purchases a truck and only 6 months were left on the plates on the truck then after 6 months one would need to renew them.
Old 06-16-2011, 11:44 AM
In CA, our tags are due every year with a *diesel "Smoke" test every other year. Unlike AZ, there is no "diesel engine" grace period like gassers get.
* - They plug into the OBDII port, do a 'visual inspection' to make sure the stuff that is supposed to be there is and then the 'smoke' test to make sure it isn't smoking too much or too long.
Old 06-16-2011, 11:54 AM
Your luckey just every 2 years. It is every year for diesels. Gassers go onto a 2 year inspection & plates.
The new all electric can do the 5 year deal.
Old 06-16-2011, 12:23 PM
SHHHHHHH - QUIET!!!!
With the way our state budget is over here, all we'd need is to have them start once-a-year testing.
