Dum EGT Question Of The Day
I just qot an edge insight in my truck and was wanting to know what is a high side I should not go over. and where should i try to keep under.
What brought me to this was i was driving to work to day with my new toy and it regend and was 1050-1150 EGT Thanks JJ |
During regen these trucks get hot. Normal Driving 1150-1200 should be your warning alarm. Above those temps is fine for short bursts but not extended driving. I would keep it below 1600 as your upper benchmark. As for normal driving it should run between 600-800 depending on your speed and the roads.
sit tight on the trailer pulling.... i had an edge on a dodge i used to own, and would run it on stock pulling a 24' gooseneck loaded with cows (15k or so) in moderate hills running 70-75 and running up hill trying to keep 70 truck would de-fuel.... i set egt's max at 1200.
im not saying dont pull a trailer at all. im saying dont expect to run a tune on a stock truck and expect to keep egt's low. atleast thats how my dodge was. fixin to order programmer for my ford and we'll see how it takes it. it may be a totally different animal.
I pull the passes here in Colorado many times a month. 2 of the passes are on diesel powers toughest passes in the country. Eisenhower, and vail. That being said I can pull the passes with a 11k pound trailer in my 210 tune at 65mph and not have egt's get above 1050. This is in my 210 tow tune. If Im in my 250 tune things will start to get hot. Full list of mods are in my sig.
I wouldn't worry about 1200 sustained, 1350 is about the end of my comfort zone, I'll back it down at 1400.
My remote start is a clifford. Works like a charm and has a cool down timer that I run in the summer time. I have it set for 45 seconds after I turn the key off.
