2008 F250 TPMS Band Vs LATER SENSOR
Ok so apparently my 08 has the tpms with the band. My after market wheels and tires need tmps so that I can switch in winter and summer. However do I have to put the band or will the newer sensor work. Also if i need the band what do I need. Ford wants $190 a tire for band and senor can get a set of 4 on ebay for $130
If you are running larger tires?, If you are, do you think the stock bands will keep the light off or do plan on running 65psi in the aftermarket tires , I would love to find away to get my tpms light off without taking apart the dash
There has got to be a way to ditch the light or run less tire pressure
If you are using a H&S tuner they will be coming out with an update to adjust or disable the TPMS
Damn it ! No way
I don't believe the new sensors will work with the old tpms system.
they do......unless i just bought new bands to hold the sensors,,,,, im not sure on that one....ill go look for my receipt.... YEAH...PAID $49 FOR NEW BANDS, not sensors
i would sale my spartan just to get the light off ha ha, its that annoying
