08 f350 w/ 97k miles - needs front end susp. work - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-29-2011, 10:20 AM Thread Starter
went in to get a alignment today and they said they cannot do it
without changing the left outer pitman arm, left and right tie rods (both boots are ripped)
they wanted 1k to do it all, anyone have experience with this? it seems very easy to buy the moog parts online and diy,
also how can you check to make sure these parts are bad/loose?
2009 f250
H0USE is offline
post #2 of 6 Old 04-29-2011, 10:37 AM
I would take it to another shop for a second opinion. or buy the parts do it yourself and then take back in for the alignment. either way I would still get a second opinion to make sure your not replacing something that doesn't need to be.
2008 F250 CC 4x4 6.4 liter
TBentley is offline
post #3 of 6 Old 04-29-2011, 05:00 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
I've seen the right side tierod sleeve go bad in as little as 20k miles. with almost 100k on it it's definitely possible all those pieces are worn
the pitman arm doesn't go bad but the inner drag link joint can in which case you need to replace the entire piece. it's probably pretty costly. parts will add up fast then add a couple hours labor for the install and i can see a grand going fast.
raise the front of your truck, wheels off the ground, and shake them side to side to feel for looseness.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 6 Old 05-05-2011, 01:41 PM Thread Starter
does the tie rod and sleeve come as 2 different parts?
2009 f250
H0USE is offline
post #5 of 6 Old 05-08-2011, 10:57 AM Thread Starter
when i get new outer tierods, should I stick with moog vs. the offbrands from the store? also do I need new tie rod sleeves, or can I reuse the stock ones.
lastly the drag link has play in it if I rotate it with my hand freely, is that worn out? would I need the entire thing new or can I just get a new drag link end?
2009 f250
H0USE is offline
post #6 of 6 Old 05-09-2011, 06:04 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
i have heard moog makes good tie rod ends. I think i will go with moog when its time. For ball joints i am going with dynatrac
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
