New 6.4 guy few questions
What oil/oil filter are you all using?
What fuel filter? im sure i could of used the search but its really hard to see on my phone |
Be sure to use the Ford oil filter and cap. After market screws up the injectors. I use all Ford filters and oil. Hope this helps
okay i was wondering cause i was going to just take it to ford but F that once i found out how much it was. I have NO problem doing it myself
I do mine but get my filter at Ford. Also be sure the oil filter cap is Ford. If not get one and save your injectors.
You can never go wrong with Ford's Motorcraft filters, but if need be my second choice would be WIX
heard of probs with wix not seating the spring in the filter container and that disables the bypass and starves the engine. just passing along something i have read
okay well looks like i will be getting ford stuff
motorcraft oil and filter same for fuel filters, don't stray from motorcraft or raycor. I get mine from walmart. they are the cheapest i have found
I use Fleetguard oil and fuel filters. I also use Shell Rotella.
okay thanks everyone i have a few more questions now.
Picked up a daystart leveling kit will i need anything else for it if i install it? How big of tires will fit under it? 35? For exhaust do they have a full 5in kit? |
