transmission fluid change - Ford Powerstroke Diesel Forum
Old 04-18-2011, 06:04 PM
ok. i am sure that this has been discussed before, i just can't find the thread.
i am getting ready to change my job 3 tansmission fluid. probably going to go with amsoil. i have had really good luck with their products. also probably gonna do the mag hytec pan at the same time.
question #1: anyone on here have any experience with the amsoil transmission fluid?
question #2: what is the best way to drain all of the fluid out? every last drop? since i am switching to synthetic i would really like to get it all out. does the torque converter have a drain, or rubber plug?
question #3: finally, does anyone make a better filter, or is the motorcraft the best?
thanks in advance. i am sure someone has already gone down this path, just wondering the best way to do it.
Old 04-18-2011, 08:31 PM
I recently changed my tranny fluid out with Amsoil fluid and noticed an imediate difference in the shift firmness. Also running 10-15° cooler normal driving, haven't yet towed with the new fluid.
I'm not sure if other filters are better or not but examining the design I beleive the OE is fine. Here is how I did it.
1. Drain oil and remove pan, remove filter(make sure you get the rubber seal out of the valve body, it usually gets stuck up there)
2. Replace filter and pan re using original pan gasket. Fill pan with new fluid, approx. 8 quarts.
3. Disconnect tranny cooler lines from radiator and cooler, blow out cooler with air(you can pull the lines down behind the bumper to get them closer to your catch pan).
4. With the pan under the tranny lines, start your truck and monitor the fluid coming out, once it starts foaming shut the engine off(about 20 seconds).
5. Fill the trans again and repeat the process untill you see new bright red fluid coming out(I put approx. 17 quarts in by this point).
6. Re connect tranny lines, start engine and let run for a few minutes, cycle through all gears. I then drove it a few miles.
7. I ended up putting in an additional 2 quarts to get it in the middle of the full scale for a total of 19 quarts. Exactly what Amsoil says the capacity is.
Note: I recommend sealing the two piece dipstick tube at the joint about 6 inches up from the tranny with some RTV silicone, it allows moisture to get in the tube causing a rusty condition. I even found a little water in the bottom of my pan.
I hope this helps. Its really pretty easy and I am confident I got all of the fluid replaced.
Old 04-19-2011, 03:59 PM
thanks for the info bowkill. sounds like you have got that process figured out.
Old 04-21-2011, 06:08 AM
Note: I recommend sealing the two piece dipstick tube at the joint about 6 inches up from the tranny with some RTV silicone, it allows moisture to get in the tube causing a rusty condition. I even found a little water in the bottom of my pan.:
On 2. You didn't need a new gasket? How long had it been since you had the pan off the last time?
On 3. and the note. Could you get pics of the area's when you get a chance. I don't want to pull the wrong lines.
Great write up.
Thanks
Old 04-21-2011, 06:44 AM
I know a lot of people switch tranny fluids, but I am not a fan of switching fluids in something with clutches and bands.
I would stick with the Mercon SP or the new one that replaced it, cant remember the name of it right now.
Once I start running a tranny on something, Dextron, Type-F, etc. I dont change it from that type. Just something I have always been a stickler about.
Old 04-21-2011, 06:56 AM
^^mercon sp or lv
