EGT Sensor - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-14-2011, 05:35 PM Thread Starter
powerstrokeghost2008's Avatar
EGT Sensor
Went to my local ford dealer and purchased 3 egt sensors, but my problem is this. One of the EGT sensors is shorter than the other 2 and has a different plug on the end and cost 20 dollars more. The box says it is a sensor!!!
Here are the Part #'s: 8c37-12b591-e (that's the small one)
8c3z-5j213-d (that's the 2 long ones)
They told me these were for the 6.4L. This is my first diesel pickup so I would be very grateful if someone could help me!!!! THANKS, Tyler B.
powerstrokeghost2008 is offline
post #2 of 4 Old 04-14-2011, 07:42 PM
The short one goes into the exhaust manifold to turbo up pipe located on the passenger side.
2008 F350 6.4 4x4 DRW CC 4:10 King Ranch Job3
Max2006 is offline
post #3 of 4 Old 04-14-2011, 07:51 PM Thread Starter
Thanks for answering my question I really appreciate it. I was thinking about installing the dpf/cat delete myself!!
post #4 of 4 Old 04-15-2011, 01:19 PM
The short egt sensor is not changed for cat/dpf delete.
The cat/dpf assy only uses the two long ect sensors and and a pressure sensor..
A nipple is needed to connect the the pressure sensor tube to the the delete pipe. You may have received the nipple with your pipe.
Max2006 is offline
