Oil Analysis - 20K miles - Showing High Aluminum
Just got my 4th oil sample back from blackstone...my 20k oil change. They are noting high levels of aluminum so I'm wondering if I should be concerned. I've attached the current report which also includes the previous 3 samples. Been running Rotella T6 full synthetic since the first change at 4800 miles. Installed the Spartan DPF/DOC delete at about 12k. I baby the truck and only tow (6k trailer) very rarely.
Anyone have any other ideas or interpretations? |
I would send in for a report in between changes. Like the next 2500 miles. A spike in aluminum is really nothing to worry about unless the next report shows as high or higher amount. The source for the aluminum is most likely pistons.
Both my oil analysis came back the same way and the guys who did the analysis are concerned with the high numbers.
I run Coop DMO SL 0W40 full synthetic. My summer results with 15,000km's on the oil came back at 20PPM. My Winter results with 13,000km's on the oil came back at 30ppm. Truck now has just under 90,000miles on it. |
Why I did it! |
Sorry, I mixed km's and miles in my post. My readings for the oil is in km's so in the 7500-8000mile range. My summer run had more miles and resulted in less aluminum and iron. If anything I will have to drop back the mileage between changes in the winter. Ford manual says you can run 16,000km's between changes if it isn't extreme conditions. Summer here is not extreme and I don't pull with the truck other then a 3500lb boat from time to time. Only extreme it sees is my commute to work and back which is 15mins from start to stop each way. I also don't idle or warm the truck up. |
I don't understand high piston wear on a non-regening diesel. These oil analysis results are consistent for this engine and I'm starting to wonder who "long life" this engine really is.
My buddy has 300,000km on his 08. It was all highway miles in Alberta Canada and was all stock up until last fall when he bought it. It seems to be going strong and he is running my 525 tune on it with no issues other then I think he has a leaky injector because the truck makes oil even when he has the emissions crap off the truck.
Just sent in for another analysis...5,000 miles after the last one (24,000 total miles on truck).
The aluminum actually went up to 30 ppm. The blackstone comments say that it is now probablt from the EGR system...Here is the full report. I'm thinking about changing my oil on the next change. Last edited by blackbirdxx; 06-14-2011 at 08:27 PM. |
When I ran the rotella full syn oil for 10k miles I had the same issue that you are experiencing, high aluminum. I switched oils and have never had the issue again. This is the oil i run. Valvoline extreme blue full syn. Works great.
Valvoline.com > Products > Motor Oil > Diesel Motor Oil > Valvoline Premium Blue® Extreme Diesel Engine Oil |
Amsoil FTW
