Wiring the rocker switchs....... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-07-2011, 01:48 AM Thread Starter
dogrider's Avatar
I am wanting to wire a 12v pump for my bed fuel tank and was wanting to use the factory rocker switchs. Does anyone know best way or how to get to the wires. Are they already hot? Also I know theres different fuses. Which fuse size should I use for this. Thanks Chris
dogrider is offline
post #2 of 7 Old 04-07-2011, 03:19 AM
greasltn's Avatar
The wires for the upfitter switches are under the dash on the drivers side. They should be labeled if no one has taken it off. The #1 upfitter switch is fused for 30a.
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
post #3 of 7 Old 04-07-2011, 09:04 AM
I have had a hellofa time trying to figure out exactly what wires are for what? The 2010 owners manual says one set of colors but I cannot find the ones that match. I have found the 8 blunt tips under the dash and the 4 blunt tips under the hood. I have posted a few pictures hoping someone could kick me in the right direction.
Under the Dash
Under the Hood
Muldoon is offline
post #4 of 7 Old 04-07-2011, 04:31 PM
bman848's Avatar
Under the Dash
Under the Hood
I think you have the wrong wires. If you dig a little deeper, you will see 4 wires above those. These are the wires you need. I just hooked my amp up to these last week. I saw the cluster that you have there but they did not match the diagram I had. After some searching i found the right ones. They are not the easiest to get to though.
08 4X4 Harley Davidson Edition
4 Inch Lift
35" Hankook A/T Tires
18" A/E Chrome Wheels
Westin Polished Running Boards W/ LED
5% Tint
Bullydog Cold Air Intake
SCT Livewire Extreme, KEM Tune
4" DPF/Cat Delete
Pair of Kicker Comp. 10's behind the seat.
Soon to come:
Smoked Tail Lights
bman848 is offline
post #5 of 7 Old 04-07-2011, 05:29 PM
08spartan250's Avatar
i'm really interested in this too. i am about to get some lights that i am going to want to hook to these switches. whenever you find the right ones, will you post some pics up?
-Mike
2005 F-250 Lariat
Originally Posted by azkcr View Post
And you didn't know Cummins can manage 127mpg??? They also deliver babies, go to Mars, and cure AIDS. DUH
08spartan250 is offline
post #6 of 7 Old 04-07-2011, 08:23 PM Thread Starter
dogrider's Avatar
The wiring today went smooth. The 12ga yellow is aux1 on your switchs. I didn't go through and test other 3 but easy with a test light. Then under steering wheel theres a bundle of a bunch of wires the 4 largest which i think are 12ga wire are the ones that run through the fire wall. Not sure where all others go. I used the orange with gray strip. And wired pump to it. Worked like a charm. Anyone have question Ill try in help. Truely not hard at all. Thanks 4 all the help............Chris
dogrider is offline
post #7 of 7 Old 04-08-2011, 08:56 AM
Thanks for the help fellas. I'll dig into it today!
Muldoon is offline
