dpf delete tunes - Ford Powerstroke Diesel Forum
Old 04-06-2011, 01:50 PM
dpf delete tunes
Can a truck run with the dpf still attached to the exhaust system(not removed) but with a tune so its never operational? I am just curious.
Old 04-06-2011, 01:58 PM
Some tuners give you the option to run with the dpf installed. The truck will still have to regen the dpf, and the times for some are greatly increased = lower mpg & power.
Old 04-06-2011, 04:29 PM
i guess what i was asking can i cancel he regen process in a 6.4 but leave all factory exhust? basically, can the regen process just get turned off?
Old 04-06-2011, 06:16 PM
I think you COULD turn it off by choosing the dpf delete choice when you install the tuner... But WHY? The filter will clog that much sooner causing more problems than they do when the operate, even killing your engine.
Old 04-07-2011, 03:07 AM
thx, If it will clog and screw theings up then you cant. I guess technicaly you could. Thats the answer I was looking for.
Old 04-07-2011, 07:13 AM
I bet you could. If you disconnect the sensors and tell the tuner there is no DPF it should work. As already stated, the DPF would fill very fast and kill the engine.
