RADIATOR LEAK
I HAVE 2008 JOB 2 6.4. TRUCK HAS 45000 MILES ON IT AND JUST STARTED LEAKING FROM TOP OF RADIATOR. FORD SAYS NOT COVERED BY ENGINE WARR. BEST PRICE I HAVE FOUND ON NEW RADIATOR IS 850. CAN THESE RADIATORS BE FIXED OR MUST THEY BE REPLACED? WILL TRUCK CONTINUE TO EAT RADIATORS??? THANKS
I had my 08 6.4 radiator replaced under warranty. The Ford service guy told me their had been some issues with the radiators in the 6.4. Wonder if they have some sort of service bulletin out on that? I think mine was under the first build date. I bought mine in Feb 07.
Ford will replace if thermostats are the cause. Otherwise you are stuck. Mine cost $1100 to have done.
Dang that is one expensive radiator replacement!!!
just had mine replaced. $1500. check 1-800-radiators. Heard they have good prices if you want to DIY instead of going thru the stealership.
thanks. i ended up at 1100 to replace. but fmc no help, said i should have gotten esp. i said thanks alot for that little tip, but last time i checked a new diesel should last longer than 45000 miles before it needed a new rad.
theres a thread on here of a guy selling a NIB radiator for $500
