Switching from 33's to 35's= really bad mpg - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-02-2011, 07:01 AM Thread Starter
jac97psd's Avatar
So I had 18 inch wheels with goodyear duratrac 33 inch tires. I was avg around 19-20 mpg per fill up. I mostly do highway driving. But now I got some 20" factory wheels with goodyear duratrac 325-60-20 which comes out to be a little bit bigger then a 35" tire. Well I've had this 35's on the truck now for two weeks and I am avg about 15-17 mpg per fill. Will switching tires make that big of a difference in my mpg? I knew it would drop some but nothing like I am seeing or do I have other issues I need to be looking for?
2010 F-350 CC SRW LongBed 4X4
Spartan tunes, 5 inch Flo-Pro w/ DPF Delete, AFE stage 2 CAI, Cold side piping, 4 inch down pipe, Rudy's EGR delete, Air Dog II
jac97psd is offline
post #2 of 16 Old 04-02-2011, 07:33 AM
doubt it i get 20mpgs with toyo 35's and factory 20s
08 Black CC/SB lariat, billet grill inserts, Toyo 35X12.5R20 open country m/t, Newton lift 2.5" front with 5" blocks
Spartan 275, 5" downpipe back SS w/ 18"x6" tip, AFE Stage 2 PG7
4" custom downpipe being made
madman1234509 is offline
post #3 of 16 Old 04-02-2011, 07:35 AM
Feedback Score: 5 reviews
Is that hand-calculated WITH your speedometer AND odometer adjusted to make up for the difference in tire side? (Rim size only changes ride quality)
ToMang07 is offline
post #4 of 16 Old 04-02-2011, 07:39 AM Thread Starter
jac97psd's Avatar
Yeah that's hand calculated. But I do need to adjust the speedometer and all. I guess I need to go spend a 100 bucks at spartan.
jac97psd is offline
post #5 of 16 Old 04-02-2011, 07:40 AM
Stock Tire - 33x12.50R18 >Search Tires Tire 1 - 35x12.50R20
Rim Diameter: 18 in - Rim Diameter: 20 in
Overall Diameter: 33.02 in - Overall Diameter: 35.02 in
Radius: 16.51 in - Radius: 17.51 in
Circumference: 103.7 in - Circumference: 110.0 in
Revs per Mile: 629.9 - Revs per Mile: 593.9
Actual Speed: 60 mph - Speedometer1: 56.5 mph
Speedometer Difference: 6.061% too slow
Diameter Difference: - Diameter Difference: 5.72%
This is a quick conversion chart I pulled up, going from 33-35" tires.
http://www.1010tires.com/TireSizeCal...?action=submit
ToMang07 is offline
post #6 of 16 Old 04-02-2011, 11:03 AM
Warheads on Foreheads
superdutydixie's Avatar
Tire Size Calculator - tire & wheel plus sizing
love that site, use it all the time
09 F-250 Superduty CCSB
SOLD
superdutydixie is offline
post #7 of 16 Old 04-03-2011, 10:09 PM
I was getting around 20-21 MPG (hand calculated) before suspension and tires. I went from a 32" tire to a 35", lifted the front end 2.5" and the rear 1" and went to about 17 MPG. Sometimes I think about going back.
'11 F250 Lariat CrewCab 2WD - Bushwacker flares, HID Projectors with Halos and color matched headlights, all led bulbs inside and out, Recon smoked Taillights, third brake light, and side turn signals. 35" on 18" XD775 wheels, 2" spacer in front and 1" block on rear. More to come.
'08 CrewCab 2WD Auto (RIP)
Spartan, Intercooler Pipe, Intake, Air Dog, Exhaust
'94 Toyota Supra TT - Sold
'93.5 Toyota Supra TT - 1021 RWHP - Sold
08CCSFL is offline
post #8 of 16 Old 04-04-2011, 03:02 PM
08spartan250's Avatar
wow, thats pretty surprising. i knew it would effect it, but i didnt know it would change that much. i'm about to change from a 8.5" lift with 37s, to stock height and tires. i'm hoping my mpg will jump a lot.
-Mike
2005 F-250 Lariat
Originally Posted by azkcr View Post
And you didn't know Cummins can manage 127mpg??? They also deliver babies, go to Mars, and cure AIDS. DUH
08spartan250 is offline
post #9 of 16 Old 04-04-2011, 03:23 PM
ok so idk how to "hand" calculate it. now i kind of want to know what my mpgs are.
2003 F-350 CCLB 7.3L XLT Sport FX4
7.5" Custom Superlift, 37" Toyo M/T, 20x10 Black Fuel Hostage, 4"-5"-6" Black Aussies, 20% Tint, 05 Harley Headlights, Recon Lighting, Dixie Horns, 08 Mirrors and Taillights, 05 Emblems, Custom Audio/Video System, Billet Grill, HID's, 2 Yellow Top Optimas, N-fab Black Nerf Bars, DIY 6637 Intake, Foil Delete, & TGC Dual steering stabilizer, Wicked Wheel, Isspros & DP-Tuner.
landyacht27 is offline
post #10 of 16 Old 04-04-2011, 03:41 PM
Use the tire size calculator above to calculate how far off your speedo is. Say it's 5% off, and you go 200 miles according to your odometer. Your actual mileage is 210 miles. (200miles x 1.05)/Gallons used = MPG.
ToMang07 is offline
