stuck in the mud questions??? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-31-2011, 06:45 AM Thread Starter
Quoted: 33 Post(s)
first off let me say 4x4 trucks with "open rears" is just dumb. a factory optioned "snow plow package" should include limited slip rears.......
i was stuck in the field with a trailer, not deep mud just pasture, like almost up to the wheel but not, just total sidewall coverage....... i know the truck needs new sneakers......
question is when pulling forward while spinning- when i came to rest i heard the truck spool down and the brake peddle got really hard and then truck stalled. it diod this both in forward and reverse each time the truck stopped with forward motion, rocking to try to get un stuck....... is this normal? i noticed today (3 days later) that the canaster at the master cylinder(looks like a soda can on its side) is moist and there is a line of fliud on the frame rail under this.......
gwilkrrs is offline
post #2 of 5 Old 03-31-2011, 04:39 PM
Send a message via Yahoo to skipnay
Mine has the limited slip in it and mine gets stuck all the time and need to put it in 4 wheel drive. I had actually talked the service guy into tightening the clutches in my rearend. It has helped!!!
2010 My Wife has 2 Full time JOBS NOW
2008 F250 H&S MiniMaxx, S&B CAI, and cat/pdf delete
2008 Brute Force 800 All hooked up 67hp to the wheels
2007 Got Married
2004 KFX 700 Stock Bore Kit XX cams
1990 Mustang Notch getting ready to hook it up
1988 Mustang GT 449hp to the wheels 6sp Getting a cage installed
skipnay is offline
post #3 of 5 Old 04-01-2011, 08:18 AM
STROKMII's Avatar
Was your "Traction Control" switched OFF???
I was out in the snow this winter and I was driving down a 2ft deep snow covered road and the truck was very low on power and the brakes were acting funny, then I noticed that the "TRAC" light was staying on in the INFO Center. So I turned "Trac" OFF and truck drove normally....
Carl
2012 Raptor Supercrew....LOADED!!
TRADED IN...2008 6.4L F250, 4x4, CC, SB, SRW,4" lift, 315/70/17 BFGs, Mini Maxx, HOT DAMN TUNE, DPF delete, MBRP exhaust, Muffler Delete, Air Raid CAI, MBRP CAC pipe. 579hp/1323tq
1987 951,Roll cage, Heavily modded,300hp/314tq, getting bigger turbo hoping to get to 400hp
2010 4Runner,4x4, SR5, stock.... not for long...
STROKMII is offline
post #4 of 5 Old 04-01-2011, 08:53 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
Yea, if you have traction control and get stuck it doesn't know what to do with itself.
strokinpower is offline
post #5 of 5 Old 04-01-2011, 09:06 AM Thread Starter
Quoted: 33 Post(s)
no its a job 1 truck without traction control option......
gwilkrrs is offline
