Factory driving lights not working..... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-29-2011, 09:02 AM Thread Starter
my factory driving lights stopped working this morning. i'm pretty certain that both bulbs didn't go out at the same time but i guess it's a remote possibility. where is the fuse panel so i can see if maybe the fuse went out? if that is not the case, has anyone else had this problem.....and if so, what was the solution?
wide body is offline
post #2 of 7 Old 03-30-2011, 07:55 AM Thread Starter
so i finally found the interior fuse panel, and looked at the only fuse i could find that mentioned anything about "fog lamps" and the fuse looked good. do you guys have ANY ideas what look at next?
the book lists it as "fog lamp relay feed, cornering lamps". so i'm assuming there is an actual relay somewhere? where is that? what do they consider cornering lamps? do i have those? i believe all of my other lights are working.
post #3 of 7 Old 03-30-2011, 08:24 AM
It is possible that both lights have gone out at the same time. I would remove the light and look at it to see if it is burnt out. If you can't tell then I would buy a light and put it in if it works then you knwo it was burnt out and if it doesn't you know you have an electrical problem somewhere. You will use the light at some point anyway so it's not like you are wasting money. Good Luck let us know what you find.
Ed
2009 PSD FX4 Crew Cab Bed X Liner Stock
When she's paid for mods
sportsfreaked is offline
post #4 of 7 Old 03-30-2011, 08:37 AM Thread Starter
thanx for the input. i forgot to mention in my original post that the little orange indicator on the headlight switch does not come on either. i will check the bulbs and see if they did go out at the same time. the other thing i'm going to do is see if i have power at the lights. if not, than i'll see if i can somehow get to the switch itself and see if i have power at the switch and just keep working my way backwards. for some reason i'm getting the distinct feeling this is going to be expensive.......
post #5 of 7 Old 03-30-2011, 09:38 AM
Send a message via Yahoo to skipnay
I have fog lights but not day time driving lights.
2010 My Wife has 2 Full time JOBS NOW
2008 F250 H&S MiniMaxx, S&B CAI, and cat/pdf delete
2008 Brute Force 800 All hooked up 67hp to the wheels
2007 Got Married
2004 KFX 700 Stock Bore Kit XX cams
1990 Mustang Notch getting ready to hook it up
1988 Mustang GT 449hp to the wheels 6sp Getting a cage installed
skipnay is offline
post #6 of 7 Old 03-30-2011, 12:16 PM Thread Starter
small update.....
fuse looked good, have power at the fuse but no power at the lights themselves. going to see if i can get to the switch wiring this afternoon, and also try to track the wiring from the lights and see if i can get lucky and find where the power ends.....
post #7 of 7 Old 03-31-2011, 06:32 AM Thread Starter
i ran out of time yesterday afternoon and didn't get a chance to "wire chase". BUT when i was pulling out of my driveway this morning, i turned on the parking lights and pulled out the switch to turn on the driving lights.....BINGO they came on!! i turned them off, then back on and NOTHING
am i correct in thinking that should tell me that the problem is in the switch? i would think if a relay was bad it would be bad....period. it wouldn't work one time and not the other correct? i'll still trace the wiring and see if there is some type of short that is causing this headache.
any opinions?
