What oil to use after DPF delete? - Ford Powerstroke Diesel Forum
Old 03-24-2011, 09:56 AM
Was wondering what oil i should use after doing a DPF delete and tuner. Wondering what your guys' thoughts were?
Old 03-24-2011, 02:09 PM
I would run the oil your normally would run in it... i like mobil delvac
Old 03-24-2011, 07:58 PM
90% here will say Amsoil or Rotella full synthetic
Old 03-24-2011, 10:39 PM
i put the kind that keeps the truck running, aka CI4/CJ4 rated 15w40(in normal temps)... keep it simple..
Old 03-25-2011, 09:52 PM
I've used Motorcraft in all my vehicle's. No complaints.
Old 03-25-2011, 10:26 PM
motorcraft here too.
Old 03-27-2011, 06:28 PM
With the DPF gone you can use a CI-4+ oil now instead of CJ-4. With the DPF you have to use CJ-4 due to the low-sulfated ash content. Without the DPF the CI-4+ oil's offer better protection with the higher sulfated ash content. I would run AMSOIL HDD5W-30 or AME 15W-40. Zink is a good thing and there is more in the CI-4+ oil's.
Old 03-28-2011, 03:53 PM
Depends on if you are planning on ever putting the truck back to stock and taking it in for warranty work.
I would stick with a 15W40 CJ-4 blend at 5k intervals for that reason. I ran Motorcraft the first 2 changes, Rotella on the 3rd, noticed a 4 to 5 degree increase in oil temps with the Rotella, and have a case of Valvoine 15W40 Premium Blue in the garage I am going to try next.
Old 03-28-2011, 04:04 PM
im running the mobil one synthetic 5w40 oil, is it ok to run the 5w40 in the summer when its warmer out here in michigan? dpf delete, 5" exhaust and black maxx on hot damn tune
Old 03-28-2011, 04:20 PM
thats what i run and have worked in south texas during the summer no problems here.
