New here, questions on 2008 F350 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-24-2011, 07:06 AM Thread Starter
bigt2317's Avatar
Hey guys, I'm new here but not new to ford or powerstrokes in general. I just got a completely stock drivetrain 2008 Kingranch F350 4x4, I've done some searching around here and started reading up on mods and whatnot but still have a few questions.
1. I believe I have a job 3 truck as the build date is 1/08, so if I wanted to go with a AFE intake or something I shouldn't have any issues right?
2. Eventually I'd like to tune it, DPF delete, and intake but not sure I want to lay the lump sum to get a kit or just do the air filter first and piece mill it together later, opinions?
3. Are there any "free" mods with these? I know my dirtbike and atv's have some hidden free mods that can be done, not sure on these?
I love the truck and I've only found 2 issues with it so far, 1 is the stupid passenger side air getting hot while drivers side blows cold thing and the other is the annoying "clicking/tapping" inside at the trans tunnel.
Any help to get this "noob" on my feet and running will help
Thanks,
Travis
bigt2317 is offline
post #2 of 9 Old 03-24-2011, 07:18 AM
LHMissions's Avatar
Welcome to the forum - and the Addiction!!!
'03 6.0 F250 FX4 Supercab Longbed 4wd <>< - SOLD
225,518miles!
Diamond-Eye 4" Off-road turbo-back
Full DIY ERG delete, Zoodad Mod, 5R110
ARP studs!!! and Decked Heads, Autometer EGR & Glowshift EOT, ECT, Boost
18x9 Black DC-2 and LT295/70R18E Nitto Terra Grapplers
LHMissions is offline
post #3 of 9 Old 03-24-2011, 07:26 AM
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
man that truck sure does sound familiar
as far as tuning goes...i just installed my mini maxx, dpf/doc delete pipe, and afe stage II pg7 and i absolutely love it
free mods
never heard of any of those for these model trucks
lets see some pics of that ride you got
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #4 of 9 Old 03-24-2011, 07:30 AM
First welcome aboard and congrats on the truck.
1. Yes you can go with the AFE intake with no problems.
2. You can get the air filter now and the tune dpf delete later. The dpf/delete and tuner must be done at the same time. You can't run the truck with a tuner on it and the dpf still on it. You must remove the dpf and tune at the same time.
3. Not any free mods that I know of.
The cold air on one side and hot on the other is due to the blend door actuator is bad. They are a pain in the a$$ to fix because I believe you must take the whole dash apart in order to get to it. If you do a search on here I beleive you can find some info on replacing the blend door. The clicking tapping I have no idea what that is.
The other thing with this truck is that maintenance is a must!! Check fluids weekly especially oil level and degass bottle. Change oil every 5,000 and fuel filters every 10,000. You also want to drain the water seperator on a monthly basis. It is located under the driver side on the frame rail.
Ed
2009 PSD FX4 Crew Cab Bed X Liner Stock
When she's paid for mods
sportsfreaked is offline
post #5 of 9 Old 03-24-2011, 07:30 AM
Shouldnt have any issues going with the AFE intake.
For the DPF delete, i gathered all the parts over time. I bought used stuff to keep the cost down. My total for the used H&S XRT PRO and used 4" flo pro exhaust was just under 650.
Im not sure of any free mods. Maybe the PCV mod.
2008 Ford F250 FX4 Supercab Shortbed Powerstroke Diesel
2006 Ford F350 XL Regular Cab 4x4 Powerstroke Diesel - SOLD
AW794 is offline
post #6 of 9 Old 03-24-2011, 07:37 AM
Quoted: 14 Post(s)
you can actually tune the truck and run it with the dpf and cat still on i did this for a week before i got to put my dpf on...i dont know about spartan or sct, but with the mini maxx from h&s when you set it up you select your truck and whether dpf is PRESENT or DELETED, now i would not recommend doing it for long because it tends to go into regen alot more
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #7 of 9 Old 03-24-2011, 07:54 AM
i know that ford dealerships have a mod on there computer that you can change on you ecm and it maximixes fuel pressure and ecomomy to gain like 11hp. AFE will be the best bet and i ran a banks six gun on my buddies 09 and did that with out doing the dpf. but it is better to do it all at the same time
cotter180 is offline
post #8 of 9 Old 03-24-2011, 08:36 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
I hear the same thing right by my trans tunnel. I tried to follow the noise and it sounds like its coming from under the dash more. I couldn't find any signs of it tho. It sure does get annoying.
Welcome to the forum!
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #9 of 9 Old 03-24-2011, 09:35 AM Thread Starter
bigt2317's Avatar
Thanks for all the replys guys!
I am pretty sure I'll do the intake first and the DPF delete and tuner together anyways so thats not a issue. I'm pretty anal about all my stuff and I keep everything up to a "T"!
I just ordered a HID kit for my headlights and my fogs, can't wait to put them in! I'm also looking to install on aftermarket reverse light under the rear bumper to aid backing, I'll wire them in to come on when in reverse as well as to a uplifter switch.
Also thinking about a single sub for behind the back seat, a leveling kit for the front, maybe some lights in the bed of the truck as well.
I've read up on the dual climate blowing hot problem and found you just need to take out the passenger air bag and radio, plus all the trim there to get to the part, which isn't bad but haven't found someone who's done it yet to see.
bigt2317 is offline
