6.4 Coolant flush - Ford Powerstroke Diesel Forum
post #1 of 15 Old 03-22-2011, 05:42 PM Thread Starter
Sesco4's Avatar
6.4 Coolant flush
I know that this is recommended with the 6.0 but is it something that needs to be done on the 6.4
Thanks
Sesco4 is offline
post #2 of 15 Old 03-22-2011, 10:19 PM
I think the owners manual says every 100k. Might want to check it, could be sooner - going off of memory
2008 Ford F250 FX4 Supercab Shortbed Powerstroke Diesel
2006 Ford F350 XL Regular Cab 4x4 Powerstroke Diesel - SOLD
AW794 is offline
post #3 of 15 Old 03-23-2011, 06:25 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
in a couple of months i am going to flush my cooling system with restore and restore plus and use some CAT ELC.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 15 Old 03-23-2011, 07:20 AM
why is everyone using aftermarket coolant? Im approaching 100k, i was just going to use OEM stuff. I dont see any coolant breakdown at all
AW794 is offline
post #5 of 15 Old 03-23-2011, 08:17 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
i have heard the ford gold stuff will eventually clog your oil cooler. That is why all the 6.0 guys switch
08 F350 cc/sb 4X4
post #6 of 15 Old 03-23-2011, 08:54 AM
Any coolant can clog a cooling system if it is not taken care of.
GM has had problems with DexCool and adding tablets.
The Dexcool was not the problem, the tablets were when the cooling system cooled down. Clogged heater cores, coolers, etc.
I am not a fan of leaving anything in a vehicle for 100,000 miles.
I flushed mine around 15000 or so and added a coolant filter in the truck.
Same Zerex G05 that I used in my 6.0. Never had a oil cooler problem in that truck and dont plan on it in this truck.
Troy Simmons
08 F450 4x4
tbsimmons is offline
post #7 of 15 Old 03-23-2011, 09:08 AM
have you noticed any difference with the coolant filter? Is it noticeably cleaner?
AW794 is offline
post #8 of 15 Old 03-23-2011, 09:43 AM
Mine was clean to start with, only 15000 on the truck when installed. The 6.0 I put one on had about 40,000 on it. It did clean up the coolant. I noticed by the stuff you can see on the sides of the degas bottle.
I think the trucks should come with them.
Depending on the mileage of your truck, I would drain the radiator, pull the plugs in the block, full with water and warm the truck up. Drain again then fill with 50/50. I just drained everything once. On the 6.0 I flushed it twice. It was dirty though, at least in my opinion. Keep the coolant clean and it wont clog anything.
Troy Simmons
08 F450 4x4
post #9 of 15 Old 03-23-2011, 10:06 AM
the problem also is that the ford gold coolant doesnt even meet the standard CAT EC1 ratings for diesel motors.. wet sleeved motors need protection.
Dietoremain is offline
post #10 of 15 Old 03-24-2011, 07:35 AM
I thought that was done with the additives. If you want it higher add some. I am sure the larger engines require more, have not read up too much on it. I have had no problems with the 6.0 or this truck so far just using the Zerex and coolant filter. If I had problems, the way both trucks are and were used, towing 90% of the time. I would have found metal parts in the filters, broken pumps, etc.
If I am wrong enlighten me. I like learning.
Troy Simmons
08 F450 4x4
